guzzler Posted March 22, 2024 Posted March 22, 2024 The brake light can be finicky without it being relay related too! I had a loose connection in the light assembly early on which made the light intermittent... Just saying. Cheers
guzzler Posted March 22, 2024 Posted March 22, 2024 Doh...just realised you checked the light! Sorry back to the normal programme. Cheers 1
GSXR814 Posted March 23, 2024 Author Posted March 23, 2024 On 3/22/2024 at 8:40 PM, guzzler said: Doh...just realised you checked the light! Sorry back to the normal programme. Cheers Expand I only went as far as confirming the bulb was OK. Filament looks fine and rear light works just no brake light. Im going to take it out for a short spin today and see if anything else stops working again😁
gstallons Posted March 23, 2024 Posted March 23, 2024 Do use an eraser to clean the contacts of the bulb/lamp and the holder . Put a contact grease in the socket to keep this from happening again . My bike did the same thing ! 2
audiomick Posted March 23, 2024 Posted March 23, 2024 On 3/23/2024 at 6:54 AM, GSXR814 said: ... confirming the bulb was OK. Filament looks fine... Expand Did you check both filaments with a multi-meter? I've had a number of bulbs for various lights that looked fine, but weren't. 1
docc Posted March 24, 2024 Posted March 24, 2024 On 3/22/2024 at 7:49 PM, GSXR814 said: I've had a play with it today. Shuffled the relays about and inspected the underside of the fuse box. It all looks OK, but it can't be as once I had refitted it all everything worked as it should apart from the lack of a brake light. Check the bulb and all the connectors and all looks good so I'm guessing I have a partially knackered relay? Expand If the front brake hand lever does not light the brake light, does the rear brake foot lever? 2
GSXR814 Posted March 24, 2024 Author Posted March 24, 2024 On 3/24/2024 at 12:06 AM, docc said: If the front brake hand lever does not light the brake light, does the rear brake foot lever? Expand I suspect, although I haven't checked, that rather than the brake light still not working it is actually permanently on. I broke a spade connector off the original and fitted the new one which had arrived the day after the issues started, initially after I broke the connector the brake light still worked off the foot brake, then nothing during the issue. Now I, thinking about it, I suspect I've managed to fit the microswitch with the plunged wedged in the light on position. I'll check it out later. All was good when I went for a 40 mile spin yesterday, briefly had no neutral light, other than that it was fine. 2
