p6x Posted April 14 Share Posted April 14 (edited) I noticed the color between my cylinder head and cylinder changing from aluminum to oily brown; It is oil wet, so I need to change the gasket on both sides. There were no traces when I purchased the bike, and it only started to appear. Is this one of the common problem? 20 years old gasket, it almost seems normal. Are there any specific good quality gasket you'd recommend? Edited Wednesday at 11:30 PM by p6x Link to comment Share on other sites More sharing options...
gstallons Posted April 14 Share Posted April 14 There are o-rings between the rocker arm assy. and the cylinder head that are hard , brittle and no longer doing what they are supposed to do . Look at a parts catalog and you will find them . Replace them and perform a valve adjustment while you are into it. 3 1 Link to comment Share on other sites More sharing options...
docc Posted April 14 Share Posted April 14 As gstallons said, #16 in the diagram, O RING (#90706203): Link to comment Share on other sites More sharing options...
gstallons Posted April 14 Share Posted April 14 Order plenty , they are not expensive. Is it #16 or #21 ? Whatever it is , they are difficult to dig out .My vision is blurry right now Thank you Docc for the technical support . 2 1 Link to comment Share on other sites More sharing options...
docc Posted April 14 Share Posted April 14 1 hour ago, gstallons said: Order plenty , they are not expensive. Is it #16 or #21 ? Whatever it is , they are difficult to dig out .My vision is blurry right now Thank you Docc for the technical support . Ah, yes: #16 x 2 (one per head?) and #21 [O RING-VITON (#90706094)] x8 (four per head?) . . . The #16 is the likely culprit. 1 1 Link to comment Share on other sites More sharing options...
p6x Posted April 15 Author Share Posted April 15 1 hour ago, gstallons said: Order plenty , they are not expensive. Is it #16 or #21 ? Whatever it is , they are difficult to dig out .My vision is blurry right now Thank you Docc for the technical support . I have an o'ring pick. This is a survivor of my oilfield days, and a gift from a dentist. You can also use a scribe to dislodge them. Here's the spare part nomenclature. Unfortunately, the description seems to be incorrect for both item #16 and #21. I should order them from MGcycle, measure them, and purchase them directly from Parker... https://www.allorings.com/Metric-O-Ring-Size-Chart https://www.mgcycle.com/index.php?main_page=product_info&products_id=4830 https://www.mgcycle.com/index.php?main_page=product_info&products_id=1382 Link to comment Share on other sites More sharing options...
gstallons Posted April 15 Share Posted April 15 Whew , it was a long time ago . Joe Eish stopped me from buying a head gasket for my SE and sold me o-rings instead . 25 or so years ago. 3 Link to comment Share on other sites More sharing options...
p6x Posted April 15 Author Share Posted April 15 2 minutes ago, gstallons said: Whew , it was a long time ago . Joe Eish stopped me from buying a head gasket for my SE and sold me o-rings instead . 25 or so years ago. You just did the same for me.... 2 Link to comment Share on other sites More sharing options...
gstallons Posted April 15 Share Posted April 15 you're welcome Link to comment Share on other sites More sharing options...
p6x Posted Wednesday at 11:25 PM Author Share Posted Wednesday at 11:25 PM Turned out, the seepage was much more simple than o'rings.... lol.... Look at the culprits... The lines bringing oil to the rocker's arms. Both sides, at the same time too. Bizarre, non? 2 Link to comment Share on other sites More sharing options...
docc Posted Wednesday at 11:32 PM Share Posted Wednesday at 11:32 PM Are those "AN" fittings and can be snugged up? 2 Link to comment Share on other sites More sharing options...
p6x Posted Thursday at 02:43 AM Author Share Posted Thursday at 02:43 AM (edited) 3 hours ago, docc said: Are those "AN" fittings and can be snugged up? could they be JIC fittings? I will tell you tomorrow, or else: https://www.crustycycle.com/products/copy-of-moto-guzzi-oil-hose-california-2-3-1100-sport-v11-sport-etc-01153602 Edited Thursday at 02:48 AM by p6x 3 Link to comment Share on other sites More sharing options...
gstallons Posted Thursday at 12:20 PM Share Posted Thursday at 12:20 PM (edited) I can tell you now . They aren't AN / JIC fittings . AN and JIC are the same. I think this is a DIN 24 or DIN 60 . I THINK some of these have o-rings and some don't . You can remove this assy and see if it has an o-ring in the hose or not. Very important ! When you break this loose , hold the fitting tight that goes into the head . 14mm or 9/16 wrenches . When you break this loose , hold the hose with a pair of channel/lock pliers or needle nose vise grip pliers to keep the hose from unwinding with the nut. W/that being said , IDK if a hydraulics shop can match you up w/the correct o-ring or not. If so , get new crush washers , o-rings and go back together . If not , get the hose assy. mentioned earlier. Edited Thursday at 12:44 PM by gstallons 2 1 Link to comment Share on other sites More sharing options...
p6x Posted Thursday at 01:02 PM Author Share Posted Thursday at 01:02 PM 29 minutes ago, gstallons said: I can tell you now . They aren't AN / JIC fittings . AN and JIC are the same. I think this is a DIN 24 or DIN 60 . I THINK some of these have o-rings and some don't . You can remove this assy and see if it has an o-ring in the hose or not. Very important ! When you break this loose , hold the fitting tight that goes into the head . 14mm or 9/16 wrenches . When you break this loose , hold the hose with a pair of channel/lock pliers or needle nose vise grip pliers to keep the hose from unwinding with the nut. W/that being said , IDK if a hydraulics shop can match you up w/the correct o-ring or not. If so , get new crush washers , o-rings and go back together . If not , get the hose assy. mentioned earlier. I remember using such connections when I was working at the AMX. Some of the tanks had a lot of hydraulics on them, such as the AMX 30 Pluton, AMX 30D. I thought we used JIC fittings on them, but I can't remember very well. I do remember those hydraulic connections with o'rings on them, and they failled easily. Metal to Metal is best for high pressure hydraulics. 2 Link to comment Share on other sites More sharing options...
gstallons Posted Thursday at 02:58 PM Share Posted Thursday at 02:58 PM You "probably" did . AN (Army Navy) was developed during WWII for the military and stayed with them. JIC (Joint Industry Council) uses the same stuff for civilian use . IT is interchangeable. O-ring face seal or flat face o-ring is on a LOT of hydraulic fittings now because of assembly speed. I don't care for this too much. DIN is a European hose connection . IDK enough about DIN fittings to explain them. 1 Link to comment Share on other sites More sharing options...
