mikev Posted April 24, 2024 Posted April 24, 2024 I noticed the other day that the signal indicator was only flashing when I set signal to right but not left. The actual front and rear signal lights worked fine for both. Hi and Low beam indicator works. Later on signal indicator worked for both directions. What causes this sort of intermittent signal indicator issue and is this a known problem & solution?
Weegie Posted April 24, 2024 Posted April 24, 2024 Is this a single indicator light on the dash that doesn't differentiate on LH or RH flasher? If it is and it's wired the same way as most of the other Guzzis of late 90s and early 2000s that I'm aware of (perhaps more models), then I'd check all the earths/grounds on the opposing flasher and all the connections on both indicator circuits and the wiring to the bulb itself. It won't work with an LED unless modified and I'd imagine strange things might occur if the bulb wattage isn't standard either It's a rather fiendish circuit where voltage is applied to the side selected and because the current is low it earths/grounds through the indicator circuits on the other side. Example you select LH flasher voltage is applied to the bulb via the LH circuit and it earths/grounds through the RH circuit. The upshot is that everything in both circuits and the warning lamp too,has to be good, connections, earths/grounds etc for it to work as intended I apologise that it doesn't answer your question precisely, but it's the best I can do for now Oh and if it has a seperate lamp for left and right ignore this post John 1 1
mikev Posted April 24, 2024 Author Posted April 24, 2024 its the same green flash for both - doesn't differentiate on LH or RH flasher, will check the connections. thanks
LaGrasta Posted April 24, 2024 Posted April 24, 2024 I can confirm this true: It won't work with an LED unless modified 1
docc Posted April 24, 2024 Posted April 24, 2024 I have had success cleaning/ treating the switch connections. CRC Electronics Cleaner, then Caig DeOxit. 1
MartyNZ Posted April 24, 2024 Posted April 24, 2024 On 4/24/2024 at 5:46 PM, mikev said: ... signal indicator worked for both directions ... Expand If you have intermittent operation of the indicators, then you have bad connections or bad grounds. If both sides flash at the same time after fitting LEDs, you need to modify your dash lamp circuit. See: https://www.v11lemans.com/forums/topic/30710-signal-indicators/?do=findComment&comment=291012 3
mikev Posted April 26, 2024 Author Posted April 26, 2024 Hey @MartyNZ Clicking to that other thread I notice your manual has a parts blowout of the instrument panel. Mine does not have this in section G Could you send me those pages?
docc Posted April 26, 2024 Posted April 26, 2024 Careful, the 2003 panel differs from the 2000 with left/right signal indicators and no "battery" light.
LaGrasta Posted April 27, 2024 Posted April 27, 2024 On 4/26/2024 at 11:54 PM, docc said: Careful, the 2003 panel differs from the 2000 with left/right signal indicators and no "battery" light. Expand truth.
MartyNZ Posted April 27, 2024 Posted April 27, 2024 On 4/26/2024 at 8:47 PM, mikev said: Hey @MartyNZ Clicking to that other thread I notice your manual has a parts blowout of the instrument panel. Mine does not have this in section G Could you send me those pages? Expand Have you downloaded the manuals Greg Bender made available? They're about 10MB. https://www.thisoldtractor.com/moto_guzzi_misc_spare_parts_catalogs___exploded_parts_diagrams___parts_fiche.html 1
cowtownchemist Posted May 1, 2024 Posted May 1, 2024 I am having the same but opposite issue. My indicator light on the dash flashes when the signalling left, but not when I signal right. I did replace the bulb with LED. So I think it will be much easier to just switch it back to incandescent instead of performing the electrical surgery needed to have the LEDs work properly. 1
Weegie Posted May 1, 2024 Posted May 1, 2024 That's what is expected if you use an LED, as it's a diode the warning light will only illuminate in one direction only, in the other the LED blocks the current. It's a bit of a faff to put the other diodes in place to get an LED to work. @Kiwi_Roy did publish a diagram somewhere on here to show the mod, but you need to get into the dash and if you're not fussed then by far the easiest solution is just to go back to a bulb 2
mikev Posted May 1, 2024 Author Posted May 1, 2024 just to be clear, my original post is not about LEDs, I just have the stock lights and turn signal indicator. 1
