Lucky Phil Posted June 25, 2024 Author Posted June 25, 2024 Fitted. Next victim the swingarm pivot locknuts and learn how to cut internal threads. 3
audiomick Posted June 30, 2024 Posted June 30, 2024 On 6/25/2024 at 8:54 AM, Lucky Phil said: ... how to cut internal threads. With a tap, I would have thought.... Seriously though, do let us know how it goes. I've been following this thread with some interest.
gstallons Posted July 1, 2024 Posted July 1, 2024 Sure , if you have a tap w/that thread pitch . Also the threads come to an abrupt stop. Just remove this jam nut and give it a look or take it to Fastenal and ask for help .
audiomick Posted July 1, 2024 Posted July 1, 2024 17 minutes ago, gstallons said: Fastenal I have the impression that Phil might have to go to some trouble to visit them. They don't seem to be present in Australia. 1
docc Posted July 1, 2024 Posted July 1, 2024 36 minutes ago, gstallons said: Fastenal I read that as "Fastena!" . . . And thought, "Damn, I remember Fast Tina, too!" 1
audiomick Posted July 1, 2024 Posted July 1, 2024 That wasn't the "leave town" story, was it? Sorry, open door..... 1
Lucky Phil Posted July 1, 2024 Author Posted July 1, 2024 1 hour ago, gstallons said: Sure , if you have a tap w/that thread pitch . Also the threads come to an abrupt stop. Just remove this jam nut and give it a look or take it to Fastenal and ask for help . I was thinking more of single point threading it and there is a larger ID visible on the outside of the nut that means you can thread all the way through. Phil 2
gstallons Posted July 1, 2024 Posted July 1, 2024 I was just popping off. IDK if that jam nut is threaded all the way or not and I am too lazy to go o/s and look . Is this going on a red frame or black frame ? It matters. 1
audiomick Posted July 1, 2024 Posted July 1, 2024 4 minutes ago, gstallons said: ...if that jam nut is threaded all the way or not ... I'm almost completely certain that, on my black frame 2002 Le Mans, it is.
Lucky Phil Posted July 1, 2024 Author Posted July 1, 2024 5 minutes ago, gstallons said: I was just popping off. IDK if that jam nut is threaded all the way or not and I am too lazy to go o/s and look . Is this going on a red frame or black frame ? It matters. Red frame. Smaller diameter. Phil 3
gstallons Posted July 2, 2024 Posted July 2, 2024 IDK if I can find a jam nut loose out in the shop but I will look and see if I can find and check the thread pitch . I am sure it is extra fine !
Lucky Phil Posted July 2, 2024 Author Posted July 2, 2024 35 minutes ago, gstallons said: IDK if I can find a jam nut loose out in the shop but I will look and see if I can find and check the thread pitch . I am sure it is extra fine ! It is 1mm pitch. Phil 2
gstallons Posted July 2, 2024 Posted July 2, 2024 The facts . The only pivot and jam nut I have is a (I measured) 20mm X 1.0 thread pitch . The outer hex is a 30mm head on the jam nut. Searching Fastenal website gives only 20x2.5 thread pitch only. You can Google and find plenty of offerings there . Not all taps/dies are created equal . Maybe someone will chime in on their favorite brand(s) of taps. The miracle of all miracles . I keep LOTS of things .a.k.a. JUNK in many plastic drawers . @ 3:45 a.m. I walked out into the shop , opened the first drawer and "presto" found the jam nut/pivot bolt . Remind Deanna to purchase Lottery ticket today ! 1 2
