red lion Posted Monday at 10:55 PM Share Posted Monday at 10:55 PM Having the fork seals changed on my 2001 rosso mandello. What is best weight fork oil to use 5W or 10W. I puchased some Ohlins 5W but I'm not sure it's the best choice. I'm about 155 lbs. Any thoughts? Link to comment Share on other sites More sharing options...
activpop Posted Monday at 11:16 PM Share Posted Monday at 11:16 PM Ohlins 1309 is what the manual calls for. Not sure what weight that is though. 1 Link to comment Share on other sites More sharing options...
Lucky Phil Posted Monday at 11:35 PM Share Posted Monday at 11:35 PM 35 minutes ago, red lion said: Having the fork seals changed on my 2001 rosso mandello. What is best weight fork oil to use 5W or 10W. I puchased some Ohlins 5W but I'm not sure it's the best choice. I'm about 155 lbs. Any thoughts? I've mentioned previously the best thing to do is measure the viscosity of the old oil and the new oil and compare the two and make a decision based on how the fork damping worked for you with the old oil. If the forks worked fine with the old oil viscosity then buy/mix and match the new oil to the same Vx. If you think you need higher or lower than the original then use new viscosities as required. Phil 2 Link to comment Share on other sites More sharing options...
docc Posted Monday at 11:41 PM Share Posted Monday at 11:41 PM SAE fork oil "weights" are a broad range of actual viscosity. Some maker's 7wt overlaps others 10wt or 5wt. The early V11 Marzocchi forks typically work better with lighter oils. I settled on (one of the) BelRay 5wt (YMMV!) by using Peter Verdone's conversion chart to centiStokes (cST), a much more accurate unit to assess viscosity. http://www.peterverdone.com/archive/lowspeed.htm http://www.peterverdone.com/archive/images/content/motorcycle/PVD-ISO-Viscosity-Data.gif Link to comment Share on other sites More sharing options...
LaGrasta Posted Tuesday at 09:12 PM Share Posted Tuesday at 09:12 PM I use ATF for all my forks, 10w by default. Link to comment Share on other sites More sharing options...
Lucky Phil Posted Tuesday at 10:36 PM Share Posted Tuesday at 10:36 PM 1 hour ago, LaGrasta said: I use ATF for all my forks, 10w by default. You can get "LV" ATF these days as well. "LV" Low Viscosity. Phil 1 Link to comment Share on other sites More sharing options...
gstallons Posted Tuesday at 10:50 PM Share Posted Tuesday at 10:50 PM Some vendors sell USD fork oil . I have read it has special powers . Mine came w/it when I had my internals worked on and new springs. I would have to go out in the shop to see the brand / wt , etc... 2 Link to comment Share on other sites More sharing options...
