Lucky Phil Posted July 6, 2024 Posted July 6, 2024 5 hours ago, alannn said: Standard lengths of 16ft and 25ft can be combined using optional DIY® Couplers for longer lengths Oh ok. Not what they do here. So the units come with the pipe connected and purged. What happens if the distance between the header and a/c unit is only 3 or 4 feet do you just coil up the pipe to shorten it? Is the pipe some sort of flexible pipe more like hose for the US units? Ours use ridged copper pipe and you cut it to length to suit your installation. Phil
Chuck Posted July 7, 2024 Posted July 7, 2024 I just coiled the excess behind the evaporator. A hivac guy I know says that is actually a good thing. 2
activpop Posted July 7, 2024 Posted July 7, 2024 4 hours ago, Chuck said: I just coiled the excess behind the evaporator. A hivac guy I know says that is actually a good thing. Not so sure that Liquid Tight would pass inspection. Maybe lose some slack and strap it horizontally to the masonry would be the trick.
Lucky Phil Posted July 7, 2024 Posted July 7, 2024 7 hours ago, Chuck said: I just coiled the excess behind the evaporator. A hivac guy I know says that is actually a good thing. Ok makes thing easier unless the unit is close to the header I guess. Phil
Chuck Posted July 7, 2024 Posted July 7, 2024 4 hours ago, Lucky Phil said: Ok makes thing easier unless the unit is close to the header I guess. Phil Quite a bit easier and didn't have to (cough cough) buy a vacuum pump and gauges. (Guzzi content) 2
