Lucky Phil Posted July 16, 2024 Posted July 16, 2024 (edited) 1 hour ago, gstallons said: The information I have I had from talking to old mechanics . The stud pulls straight up on the threads whereas the screw twists on the threads . No not really. Apart from the reduction in frictional wear from repeated use the threads in the threaded hole see the same physical stresses whether a stud or a bolt in this application. When you torque up a cylinder stud on a Guzzi or Ducati or many other engines as an example you can feel that long stud twisting under the torque load just like a long bolt. That torque is transmitted into the threaded hole just like a bolt but with without the thread frictional loss. The frictional loss is carried by the nut threads in this instance. Phil Edited July 16, 2024 by Lucky Phil 2
