Lucky Phil Posted July 31, 2024 Posted July 31, 2024 (edited) Not only the aluminium oil pump gears that fail on the high cam engines. Total rubbish. Edited July 31, 2024 by Lucky Phil 3 1
Lucky Phil Posted July 31, 2024 Author Posted July 31, 2024 On 7/31/2024 at 3:04 AM, DucatiGuzziIndian said: how many miles on that Phil? Expand Don't know the image was sent to me from Joe Caruso because we discuss engineering things/designs etc. I have several sets in my workshop with bad drive face wear on the teeth which I don't really trust for the reason shown in the image. Every material has it's place and aluminium for cam gears isn't one of them for mine unless it's some sort of sprint engine and longevity isn't an issue. Phil 2
pete roper Posted July 31, 2024 Posted July 31, 2024 I have a whole ‘Chamber of Horrors’ file of pics of Alloy timing gears and alloy/steel composite sets. None of them are, or were, ever worth a pinch of shit! Criticising them has led to threats of violence being made against me by mentally unstable and drug-fu*ked individuals so I tend not to say anything about them nowadays beyond just advising strongly against their use. I’ve spoken with Joe about these gear sets though and we’r in complete agreement. You wouldn’t use them in a lawnmower! Much less a motorbike! 3
gstallons Posted July 31, 2024 Posted July 31, 2024 I've seen gear drives , straight-cut gears ,etc. for car engines . They sound righteous . Gear driven camshafts are the norm on diesel engines , The stuff they are peddling for the M/G powerplant ? NO WAY . It is a waste of time to discourage someone from using it , they know it is what they want , let them run it and find out or "you must notta put it in there correctly" .
Weegie Posted July 31, 2024 Posted July 31, 2024 I replaced the OEM alloy gears in my HiCam engine with steel versions from Joe The OEM crank driving gear is steel, but the oil pump and cam were allo I just thought it was prudent, the amount of effort to turn an engine and compress the valve springs said to me that it might not be prudent to have alloy as a suitable material
GuzziMoto Posted July 31, 2024 Posted July 31, 2024 Gear cam drive is good, but aluminum gears for that are not a good idea for a street motor, as said. It just isn't what aluminum is good for. Strange that Guzzi went with some of the gears in aluminum for the high cam motor. But they do screw up occasionally. That said, while I would convert a chain drive cam set up to gears, I would only do so if the gears in question were steel or another suitable material. 1
Admin Jaap Posted July 31, 2024 Posted July 31, 2024 I changed my Centauro engine to chain cam drive, because I didn't want to risk exploding gears.
DucatiGuzziIndian Posted July 31, 2024 Posted July 31, 2024 Any engineer with half a brain would know alloy gears are a no no. 1
gstallons Posted August 1, 2024 Posted August 1, 2024 That is how you make something into a Hot Topic ! 1
Lucky Phil Posted August 1, 2024 Author Posted August 1, 2024 On 8/1/2024 at 12:16 AM, emry said: I didn't know this was an actual debate... WOW. Expand Where the hell have you been over the years, on the moon Phil 2
docc Posted August 1, 2024 Posted August 1, 2024 On 8/1/2024 at 12:16 AM, emry said: I didn't know this was an actual debate... WOW. Expand On 8/1/2024 at 12:22 AM, gstallons said: That is how you make something into a Hot Topic ! Expand On 8/1/2024 at 12:31 AM, Lucky Phil said: Where the hell have you been over the years, on the moon Phil Expand On 8/1/2024 at 12:35 AM, gstallons said: Well , he's officially been flushed out ! Expand We could go live with this! SSR XX is just not that far from Marietta, Georgia, @emry ! Y'all come, now! Ya hear? 2
emry Posted August 2, 2024 Posted August 2, 2024 DALL·E 2024-08-01 22.00.53 - A Moto Guzzi Scura motorcycle parked on the surface of the moon. The moon's rocky and cratered landscape stretches out under a dark sky filled with st.webpFetching info... 3
