swooshdave Posted August 12, 2024 Author Posted August 12, 2024 5 minutes ago, MartyNZ said: https://www.v11lemans.com/forums/topic/31125-help/?do=findComment&comment=299506 I measured an old TPS removed from the TB, and got 1.22KΩ. I expect the TPS resistance to be slightly higher to get 157mv. See link above. Remember that the throttle must be closed fully, which is below idle. So should we be measuring with the ignition on?
MartyNZ Posted August 12, 2024 Posted August 12, 2024 1 minute ago, swooshdave said: So should we be measuring with the ignition on? Yes. 1
swooshdave Posted August 12, 2024 Author Posted August 12, 2024 Anyone remember which coil wire goes to which coil? SX and OX? The workshop manual is a copy and doesn’t have the legend.
MartyNZ Posted August 12, 2024 Posted August 12, 2024 11 minutes ago, swooshdave said: Anyone remember which coil wire goes to which coil? SX and OX? The workshop manual is a copy and doesn’t have the legend. S means sinisterous which is Italian for left. D means dexterous which means right. 1
swooshdave Posted August 12, 2024 Author Posted August 12, 2024 13 minutes ago, MartyNZ said: S means sinisterous which is Italian for left. D means dexterous which means right. Thanks! Google Translate helped us too. Which leads us to believe the wires were actually crossed! The one thing I didn’t trust is if the Italians to map stuff while sitting on the bikes. 😜
audiomick Posted August 12, 2024 Posted August 12, 2024 43 minutes ago, swooshdave said: The workshop manual is a copy and doesn’t have the legend. Do you know of this site? https://guzzitek.org/ It's a bit "unique" to navigate, but you can find things like this there. https://guzzitek.org/gb/ma_us_uk/1100/V11_1999-2003_Atelier(Compil-GB-D-NL).pdf
docc Posted August 12, 2024 Posted August 12, 2024 3 hours ago, swooshdave said: Right? Tuning Guide says 157 mv. I put the meter on resistance (Ohms) and got this. Same thing? Sent from my iPhone using Tapatalk No, not the same thing! That is just some ridiculous coincidence that shows "1.57!" The TPS is set in millivolts (mV) to 157 mV with the throttle plate completely closed. Resistance (Ohms/Ω) are not used to baseline the TPS. Reference (and perform) the "Decent Tune-up" . . . 1
Lucky Phil Posted August 12, 2024 Posted August 12, 2024 1 hour ago, swooshdave said: Thanks! Google Translate helped us too. Which leads us to believe the wires were actually crossed! The one thing I didn’t trust is if the Italians to map stuff while sitting on the bikes. 😜 That will do it. Phil
swooshdave Posted August 13, 2024 Author Posted August 13, 2024 1 hour ago, docc said: No, not the same thing! That is just some ridiculous coincidence that shows "1.57!" The TPS is set in millivolts (mV) to 157 mV with the throttle plate completely closed. Resistance (Ohms/Ω) are not used to baseline the TPS. Reference (and perform) the "Decent Tune-up" . . . Can you update the Decent Tune Up post to say that you have to turn the ignition on for the test. I know it should be apparent but…
docc Posted August 13, 2024 Posted August 13, 2024 22 minutes ago, swooshdave said: Can you update the Decent Tune Up post to say that you have to turn the ignition on for the test. I know it should be apparent but… Sure. You are talking about the TPS procedure, yes? Done. Thanks, @swooshdave! "With a quality voltmeter, connect the positive to the violet/black wire and the negative to the violet (the yellow is not used for this setting). With the Run Switch on, switch on the keyed Ignition Switch. Adjust the TPS to 157 milivolts " 1 1
swooshdave Posted August 13, 2024 Author Posted August 13, 2024 18 hours ago, MartyNZ said: I think it's possible to swap the ignition coil supply leads. Could the same thing happen to the injector leads? Ding ding ding, we have a winner! It was the ignition coil supply leads! Pretty sure the misadjusted TPS (it wasn’t right before I screwed it up) didn’t help. It sounds spectacular! 2 1
docc Posted August 13, 2024 Posted August 13, 2024 Just so I understand, the electrical power to the void was connected wrong (right to left)?
swooshdave Posted August 13, 2024 Author Posted August 13, 2024 (edited) 2 hours ago, docc said: Just so I understand, the electrical power to the void was connected wrong (right to left)? The good news is the power wires to the coils are marked. Which is nice if you know Italian or are handy with Google Translate. Actually my friend’s wife spent time in Italy and we could have asked her too. He had replaced the TPS screws and could have easily bumped it too. Regardless, it now sounds amazing. He’s got the FbF mufflers and a Power Commander. Edited August 13, 2024 by swooshdave 1
