docdav Posted September 11 Posted September 11 (edited) My V11 sport 2001 is running slower and slower in idle, sometimes it stalls. Problem most present when engine is hot. It also has difficulty taking the gas at low rews. Where to start? Edited September 11 by docdav
po18guy Posted September 11 Posted September 11 Do you have the breakout harness for setting the TPS? That alone makes a huge difference. 2
p6x Posted September 11 Posted September 11 7 hours ago, docdav said: Where to start? There is a lot of technical material on this forum; depending on your level, you may not completely understand it. It requires a minimum understanding of some of the basics of tuning indirect injection systems. It is not overly complicated, but some of us have never really done anything mechanical. It is just how it is today. Similar to handwriting. If you have never done anything like this before, you maybe know someone that did? As @po18guy stated, do you have all the necessary hardware and software to start the task? 3
