p6x Posted Monday at 02:21 AM Share Posted Monday at 02:21 AM 23 hours ago, docc said: It is the little "tin can" under the seat @dbarb3 . . . This thing... 1 1 Link to comment Share on other sites More sharing options...
gstallons Posted Monday at 11:27 AM Share Posted Monday at 11:27 AM Hmmmm , you have the Buck Rogers version ! But , yes. Link to comment Share on other sites More sharing options...
gstallons Posted Monday at 11:36 AM Share Posted Monday at 11:36 AM H... sorry to mislead you , I said fuses and meant to say relays . The black box flasher is more durable than the can unit . 2 Link to comment Share on other sites More sharing options...
dbarb3 Posted Monday at 02:00 PM Author Share Posted Monday at 02:00 PM Found it Round metal one says Wagner 552 12 V Seems Auto Parts has these Gonna replace and see whats up 2 Link to comment Share on other sites More sharing options...
gstallons Posted Monday at 03:06 PM Share Posted Monday at 03:06 PM On 9/14/2024 at 6:09 PM, dbarb3 said: Start out by saying I hate electrical problems. The mechanics of this bike are perfect but some of these niggles are frustrating. I have checked fuses and thats about the depth of what I know to do. Front and rears both are out. After a couple of years , you will have a blown-up (laminated) (3 of them) wiring diagram close to you at all time and you will be able to put on a clinic about EVERY portion of this wiring system that could go on for 60 mins straight and you will speak w/confidence . W/that being said , jump in , the water's fine . Don't pay any attention to the jellyfish , sharks , squid or any other sea monsters ! 3 Link to comment Share on other sites More sharing options...
audiomick Posted Monday at 09:45 PM Share Posted Monday at 09:45 PM What about Cuno the killer carp? My girlfriend is convinced he is just waiting to nibble her toes off. Link to comment Share on other sites More sharing options...
gstallons Posted Monday at 10:31 PM Share Posted Monday at 10:31 PM That is your purpose ! 1 Link to comment Share on other sites More sharing options...
docc Posted Monday at 10:43 PM Share Posted Monday at 10:43 PM 8 hours ago, dbarb3 said: Found it Round metal one says Wagner 552 12 V Seems Auto Parts has these Gonna replace and see whats up Mighty easy to plug in a new flasher (cheap and commonly available) and see if the signals are restored, @dbarb3. Link to comment Share on other sites More sharing options...
dbarb3 Posted Tuesday at 12:36 AM Author Share Posted Tuesday at 12:36 AM Well not surpised new flasher did not fix it Also noticed my tail light isnt lit but the brake light comes on when applied Link to comment Share on other sites More sharing options...
docc Posted Tuesday at 12:42 AM Share Posted Tuesday at 12:42 AM 4 minutes ago, dbarb3 said: Well not surpised new flasher did not fix it Also noticed my tail light isnt lit but the brake light comes on when applied Tail light on a different circuit with the instrument illumination and low watt "city light" in the headlight bucket. Are those lit? Link to comment Share on other sites More sharing options...
MotoKnee Posted Tuesday at 03:10 AM Share Posted Tuesday at 03:10 AM 2 hours ago, dbarb3 said: Well not surpised new flasher did not fix it Also noticed my tail light isnt lit but the brake light comes on when applied In the schematic I'm looking at, it appears that the taillight and the turn signals have a wire in common. That is the wire that comes from the ignition switch and supplies power to both fuse 6 and fuse 7. Fuse 6 supplies the taillight and fuse 7 supplies the the turn signals. You could check for 12V at the input side of either fuse (red and gray wire in the schematic). If no power is present at the fuse, you may need to clean/inspect the wiring in the ignition switch. 2 Link to comment Share on other sites More sharing options...
gstallons Posted Tuesday at 09:45 AM Share Posted Tuesday at 09:45 AM Before you start , do your headlamps , horn , dimmer switch , etc. work? There may be a problem at the 10 pin connector going to the switchgear . Don't worry about this yet. Alright. It is time for you to start thinking . * # 1 new flasher installed . still no flasher. Get your test light** and see a. w/KOEO , is there 12v at one of the flasher unit connectors ? Y. apply 12v to the other connector (orange wire) to see if all the turn signal lamps light up. they should. If so you still have a bad flasher unit. Install a good known flasher and retest. N . go back to F 7 and check for B+ at both ends of the fuse. B+ ? Y , the problem is between the F 7 and flasher connector. * w/ea step , verify, verify, verify. You don't want to proceed until you are sure you pass/fail your current test. You don't want to waste your time rushing through this procedure. ** use a test light . Not a LED test light . You will learn about them later. 1 Link to comment Share on other sites More sharing options...
dbarb3 Posted Tuesday at 12:13 PM Author Share Posted Tuesday at 12:13 PM Headlights dimmer horn work brake light works How do I check the ignition swith ? Come in from under it? Talk to me like a 3rd grader on testing the voltage I have a multimeter but thats about it. Link to comment Share on other sites More sharing options...
MotoKnee Posted Tuesday at 01:19 PM Share Posted Tuesday at 01:19 PM 56 minutes ago, dbarb3 said: Headlights dimmer horn work brake light works How do I check the ignition swith ? Come in from under it? Talk to me like a 3rd grader on testing the voltage I have a multimeter but thats about it. To test for power from ign switch to fuses: remove both fuses from fuse holder. turn on key. set meter to DC volts touch black lead to negative battery terminal. then, one at a time, touch red lead to each fuse terminal. 1 side of each fuse should have 12v present. If not, you may have ign switch issue. 1 Link to comment Share on other sites More sharing options...
gstallons Posted Tuesday at 01:50 PM Share Posted Tuesday at 01:50 PM Perform the test MotoKnee recommends and report . Don't worry about the ign. switch until it is time to worry about the ign. switch. Link to comment Share on other sites More sharing options...
