speedo
OtisV11
  • 2 weeks later...
Yep thanks Roy looked at those several times in the past but as my speedo still works and just a bit wobbly in these days of electronic warfare with the cops.Mounted the sigma which is water proof and has some good functions and has worked a treat.Not that us Guzzi riders are tight wads but for $90 NZ dollars delivered im very happy with it and would recomend it for anyone wanting a cheap accurate  speedo,Cheers
On 9/26/2024 at 5:45 PM, Kiwi_Roy said:
I didn't use a Sigma, I used a Speedhut
the sensor was mounted in place of age speedo cable at the gearbox
It worked very well
I highly recommend the Speedhut line.
https://www.speedhut.com
What model dash unit did you use and did you use a new or OE tach ?
It worked very well
@Kiwi_Roy's SpeedHut set-up:
