FJFOOL Posted 3 hours ago Share Posted 3 hours ago I've heard some early 8V engines suffered from cam failures and was wondering what years and models were affected by this. Thanks in advance ! Link to comment Share on other sites More sharing options...
Lucky Phil Posted 3 hours ago Share Posted 3 hours ago (edited) 8 minutes ago, FJFOOL said: I've heard some early 8V engines suffered from cam failures and was wondering what years and models were affected by this. Thanks in advance ! Up to mid 2013 from memory. Any engine that has flat tappets, ie non roller tappet engines will fail it's just a matter of when. In the short term or medium term. Phil Edited 3 hours ago by Lucky Phil 1 Link to comment Share on other sites More sharing options...
Speedfrog Posted 2 hours ago Share Posted 2 hours ago 57 minutes ago, Lucky Phil said: Up to mid 2013 from memory. I believe the factory started the switch to roller tappets in the mid 2012. 1 Link to comment Share on other sites More sharing options...
FJFOOL Posted 1 hour ago Author Share Posted 1 hour ago ok, so an '08 1200 Sport could have this issue. Thankyou all ! 1 Link to comment Share on other sites More sharing options...
Lucky Phil Posted 1 hour ago Share Posted 1 hour ago 7 minutes ago, FJFOOL said: ok, so an '08 1200 Sport could have this issue. Thankyou all ! Unless it's had the roller cam/tappet retro fit. Lots did have as Guzzi offered kits. Pete Roper will be along shortly and know the details but you can visit the Grissogetto forum and there will be a ton of late model 8 valve cam and tappet detailed info including from Pete. 1 Link to comment Share on other sites More sharing options...
