mikev Posted Thursday at 01:49 PM Share Posted Thursday at 01:49 PM (edited) My V11 odometer just passed 30k. Its been decent weather this Fall for commuting. Also, my second season with the Road 5s and they don't show any noticeable wear yet, as far as I can tell. Maybe have put 4-5k on then so far... And, I like the stock airbox sound. Definite improvement. My next task - maybe this Winter - is to either rebuild my leaky steering dampener or get a new one. Any recommendations? Edited Thursday at 01:50 PM by mikev typo 1 Link to comment
docc Posted Thursday at 02:10 PM Share Posted Thursday at 02:10 PM Seems HyperPro has been a popular option for our V11: 2 Link to comment
Scud Posted Thursday at 07:21 PM Share Posted Thursday at 07:21 PM (edited) I followed Docc's lead on a Shindy damper for one of my past bikes and was happy with it. The stock/upgrade Ohlins unit is prettier, and fits easily. Any aftermarket unit might take a little more work, but I recall the Shindy being pretty easy to fit. I've heard nothing but positives about the Hyperpro, but not tried one myself. Unless you are really riding hard, the damper is basically there to prevent head-shake (aka tank slappers) in normal street-riding conditions. So anything that prevents large rapid movements will do that job. Edited Thursday at 07:22 PM by Scud 1 Link to comment
docc Posted Thursday at 10:44 PM Share Posted Thursday at 10:44 PM 3 hours ago, Scud said: I followed Docc's lead on a Shindy damper for one of my past bikes and was happy with it. The stock/upgrade Ohlins unit is prettier, and fits easily. Any aftermarket unit might take a little more work, but I recall the Shindy being pretty easy to fit. I've heard nothing but positives about the Hyperpro, but not tried one myself. Unless you are really riding hard, the damper is basically there to prevent head-shake (aka tank slappers) in normal street-riding conditions. So anything that prevents large rapid movements will do that job. I'm happy with mySport's Shindy ("SHIN-juh"), but not sure if they are still available for the V11 (?) Link to comment
gstallons Posted yesterday at 12:32 AM Share Posted yesterday at 12:32 AM (edited) Where did you come up w/the Shindy damper and part # plz ? Edited yesterday at 12:35 AM by gstallons Link to comment
gstallons Posted yesterday at 12:37 AM Share Posted yesterday at 12:37 AM 10 hours ago, mikev said: My V11 odometer just passed 30k. Its been decent weather this Fall for commuting. Also, my second season with the Road 5s and they don't show any noticeable wear yet, as far as I can tell. Maybe have put 4-5k on then so far... And, I like the stock airbox sound. Definite improvement. My next task - maybe this Winter - is to either rebuild my leaky steering dampener or get a new one. Any recommendations? what were you running on the throttle bodies , K & N ? Link to comment
docc Posted yesterday at 12:48 AM Share Posted yesterday at 12:48 AM 17 minutes ago, gstallons said: Where did you come up w/the Shindy damper and part # plz ? I sourced this Shindy in 2009, fifteen years ago, from Moto International, Seattle. Unfortunately, the invoice only shows the vendor's stock number, no manufacturer's part number $140US In 2009 dollars . . . Link to comment
MartyNZ Posted 21 hours ago Share Posted 21 hours ago (edited) 19 hours ago, mikev said: My next task - maybe this Winter - is to either rebuild my leaky steering dampener or get a new one. Any recommendations? I rebuilt my Bitubo damper. Once you have a tool to unscrew the end, it is easy to dismantle. A trip to the seal shop for o-rings and seals, some ATF fluid, and you have a cheap repair. Edited 17 hours ago by MartyNZ 4 Link to comment
gstallons Posted 17 hours ago Share Posted 17 hours ago I Googled Shindy last night and saw plenty of choices . M/I is a top notch M/G dealership . I will have to check and see what they have . The Bitubo rebuild sounds good too . Link to comment
docc Posted 14 hours ago Share Posted 14 hours ago 2 hours ago, gstallons said: I Googled Shindy last night and saw plenty of choices . M/I is a top notch M/G dealership . I will have to check and see what they have . The Bitubo rebuild sounds good too . Moto International in Seattle no longer exists. Link to comment
mikev Posted 11 hours ago Author Share Posted 11 hours ago 13 hours ago, gstallons said: what were you running on the throttle bodies , K & N ? PO had UNI pod filters on it Link to comment
mikev Posted 11 hours ago Author Share Posted 11 hours ago 9 hours ago, MartyNZ said: I rebuilt my Bitubo damper. .... cheap repair. I am going to try rebuilding mine. Just have to find an O-ring source. Like the sound of cheap repair. 2 Link to comment
Tomchri Posted 3 hours ago Share Posted 3 hours ago 8 hours ago, mikev said: I am going to try rebuilding mine. Just have to find an O-ring source. Like the sound of cheap repair. I did the same, works fine. And like someone said, only in use when really going wild. Only ATF +4 (Mopar),,, eeh NO. All ATF works. Cheers Tom. 3 Link to comment
MartyNZ Posted 2 hours ago Share Posted 2 hours ago (edited) 9 hours ago, mikev said: I am going to try rebuilding mine. Just have to find an O-ring source. Like the sound of cheap repair. The seals in the end-caps, and the o-rings on the outside of the end-caps are the only ones that matter. You can reuse the others if they look OK. That's because most people have the damper set to it's lowest damping setting, so internal leakage is unimportant. What is important is assembly with no air bubbles, and no external leaks. Watch the orientation of the seals in the end caps. Oh, and if you take the mount block off to paint the body (a wood.wedge will open the block enough) then measure it's location. If you try to slide the block as you install it, you damage your nice paint. I know someone with the same name as me did that. Edited 2 hours ago by MartyNZ 1 Link to comment
