docc Posted October 20 Share Posted October 20 And the battery voltage, now? What type battery is it? Link to comment Share on other sites More sharing options...
audiomick Posted October 20 Share Posted October 20 (edited) 1 hour ago, docc said: And the battery voltage, now? Further to that, what is the difference between the battery voltage measured from battery plus to battery minus directly, and the voltage on plus contact that activates the relay measured from the contact on the relay to battery minus? EDIT: I just went back over the whole thread, and saw that you have posted voltages for both of those at various times, but apparently not for measurements taken at the same time. Relevant is what the battery voltage is when it is not starting (and how much it drops when you try to start), and then how much of that voltage is actually reaching the relay. and then this: 1 hour ago, Sporticus said: Sometimes the relay will click once, the fuel pump will prime, and the bike fires right up. Other times the new relay will click sporadically (like it did before) for an extended time before the fuel pump primes. really sounds a lot like an intermittant contact somewhere. I feel that is unlikely to be a faulty relay, and you seemed to have changed all the relays already anyway. I think you need to look even closer at all the wiring, connectors and switches involved in the starter circuit. Edited October 20 by audiomick Link to comment Share on other sites More sharing options...
docc Posted October 20 Share Posted October 20 36 minutes ago, audiomick said: I think you need to look even closer at all the wiring, connectors and switches involved in the starter circuit. Classic Startus Interuptus? 1 Link to comment Share on other sites More sharing options...
audiomick Posted October 20 Share Posted October 20 (edited) Yeah, could be, but intermittent apparently. From what I have read, that is not entirely typical. Having said that, mine starts first hit sometimes, and sometimes it takes several hits on the button. When it doesn't want to start, there is only the one click, not repeated clicks. The thlot pickens... Edited October 20 by audiomick Link to comment Share on other sites More sharing options...
docc Posted October 20 Share Posted October 20 Later V11 benefit from an additional relay in the start circuit to take the stress off the ignition switch. Link to comment Share on other sites More sharing options...
Sporticus Posted October 20 Author Share Posted October 20 Checking the voltage right now would be fruitless. I rode the bike to visit a friend, who incidentally owns a relay tester (relay checked out fine). I went to leave after some time. Put key in the on position and waited for the relay to do its prolonged thing before the pump finally primed. Went to start and it just turned over. Turns out I had no spark. Related? I have no idea. Got a ride home and came back with truck and trailer, taking a ride of shame home. Further research will have to wait until I have time to pull the tank and lay eyes on the coil. On another note, the voltage at the relay has always matched that of the battery. Battery is low right now because of prolonged attempts to start the bike. 1 Link to comment Share on other sites More sharing options...
Gmc28 Posted Friday at 07:25 PM Share Posted Friday at 07:25 PM I didn’t read in this thread where you pulled/cleaned the back side of the relay attach receptacle, like Docc advised? You probably did it, but don’t think I saw that confirmed. Just spraying deoxit back there isn’t usually adequate, gotta pull the connections, inspect, clean, spray, re-assemble. Sure sounds like a semi-crappy connection. 2 Link to comment Share on other sites More sharing options...
docc Posted yesterday at 12:03 AM Share Posted yesterday at 12:03 AM 4 hours ago, Gmc28 said: I didn’t read in this thread where you pulled/cleaned the back side of the relay attach receptacle, like Docc advised? You probably did it, but don’t think I saw that confirmed. Just spraying deoxit back there isn’t usually adequate, gotta pull the connections, inspect, clean, spray, re-assemble. Sure sounds like a semi-crappy connection. Referring to these hidden connectors under the fuse block? 1 Link to comment Share on other sites More sharing options...
Gmc28 Posted 9 hours ago Share Posted 9 hours ago 15 hours ago, docc said: Referring to these hidden connectors under the fuse block? yessir. And good clarification!… thanks, as it’s both back of relay attach and fuse block thats of interest, but only the fuse block has that type of access. 1 Link to comment Share on other sites More sharing options...
Sporticus Posted 5 hours ago Author Share Posted 5 hours ago I checked those connections on the back of the fuse box and they weren’t corroded at all. I still sprayed them with Deoxit and reassembled. My bigger problem right now is that there is no spark at either plug. This happened after the fuel pump finally primed (after the relay clicked away for a minute) and the bike still wouldn’t start. I just haven’t had time to remove the tank and investigate. Stay tuned. 1 Link to comment Share on other sites More sharing options...
