gstallons Posted 13 hours ago Posted 13 hours ago I will have to compare (when I get time today) the factory diagram to Kiwi_Roy's diagram and say yes .
docc Posted 12 hours ago Posted 12 hours ago 20 minutes ago, gstallons said: I will have to compare (when I get time today) the factory diagram to Kiwi_Roy's diagram and say yes . Notice that with KOEO, Neutral Light on -> remove Neutral (#3/middle/"sidestand") Relay -> Neutral Light stays on. 1
gstallons Posted 6 hours ago Posted 6 hours ago Right now I have my hands full of a Polaris 4 wheeler and I will see about this tonight . Mea culpa , maybe ?
docc Posted 6 hours ago Posted 6 hours ago 10 minutes ago, gstallons said: Right now I have my hands full of a Polaris 4 wheeler and I will see about this tonight . Mea culpa , maybe ? There are a couple curiosities between the relays and the warning lights. The fact that the Neutral Light will stay on without the middle Neutral/"sidestand" Relay even plugged in says the light activates from the switch and is no indication of the function of the relay. Conversely, Relay #2/ "Headlight Relay" serves many functions, one of which is the charging reference. A failed Relay #2 will defeat the charging system, yet the "Battery Light" on the early V11 will not light for the failed relay. (Later V11 with left and right turn signal indicators do not have a battery/charging warning light.)
gstallons Posted 3 hours ago Posted 3 hours ago https://www.v11lemans.com/forums/applications/core/interface/file/attachment.php?id=11659 1
gstallons Posted 3 hours ago Posted 3 hours ago Well , I found this by searching "test point layout" and found it in a 2010 post of Kiwi_Roy's diagram . As you can tell I put it up here and nothing happens ! Anyone else want to improve and open this go ahead on ! 1
gstallons Posted 3 hours ago Posted 3 hours ago As you can tell I am better than (I hope) a chimpanzee ! 1 1
docc Posted 3 hours ago Posted 3 hours ago Studying that Test Point Layout, I am trying to discern if it is the early V11 wiring harness, or the later. They differ. Some aspects of that diagram differ from the wiring diagrams and may be "approximations" for expediency of the Test Point exercise. 1
MotoKnee Posted 35 minutes ago Posted 35 minutes ago 5 hours ago, docc said: There are a couple curiosities between the relays and the warning lights. The fact that the Neutral Light will stay on without the middle Neutral/"sidestand" Relay even plugged in says the light activates from the switch and is no indication of the function of the relay. Conversely, Relay #2/ "Headlight Relay" serves many functions, one of which is the charging reference. A failed Relay #2 will defeat the charging system, yet the "Battery Light" on the early V11 will not light for the failed relay. (Later V11 with left and right turn signal indicators do not have a battery/charging warning light.) I drew up the first diagram to help me understand my own bike, the second to follow what's being discussed in these threads. Both are based on Carl A schematics. I find them helpful, others may not.
