Guest SteveT Posted November 12, 2002 Share Posted November 12, 2002 I just bought a 02 Lemans. In the owners manual was a card indicating the factory oil is AGIP Racing 4T 20W-50 (full synthetic). The transmission & rear end have AGIP Gear Synth 75W/90 (semi synthetic). Anyone running full synthetic in the transmission & rear drive? SteveT 02 Red/Grey 69 V700 Link to comment Share on other sites More sharing options...
Guest Guest Posted November 12, 2002 Share Posted November 12, 2002 I've been using full synth Valvoline with a moly additive in the rear drive as well as transmission. Feels great and no complaints. Link to comment Share on other sites More sharing options...
RichMaund Posted November 12, 2002 Share Posted November 12, 2002 Forgot to log in. Sorry. That last guest posting was mine! Link to comment Share on other sites More sharing options...
TX REDNECK (R.I.P.) Posted November 12, 2002 Share Posted November 12, 2002 I've been using Mobil 1 in the engine.Castrol synthetic in the trans and final drive without the moly additive.The trans shifts are much smoother.I started using synthetics in my 18 wheelers in 1987 and have used them ever since. Link to comment Share on other sites More sharing options...
callison Posted November 12, 2002 Share Posted November 12, 2002 I've been using the BMW motorcycle transmission synthetic lube for all three of my 1100cc Guzzis. I add a fair dollop of engine assembly lube as well (no moly available locally) to both the rear box and the transmission. I also use teflon tape to seal the drain and sight plugs and safety wire them as well (on the rear box) because the synthetic lube is so damn slippery that I've had them depart the bike. Link to comment Share on other sites More sharing options...
Guest Squashed Nose Posted November 12, 2002 Share Posted November 12, 2002 I've been considering using a friction reducer such as Slick 50 or Activ8 in the engine, transmission and final drive. Has anybody used these and, if so, what benefits are there? I used Activ8 in my ZX9R and it made the clutch slip! Of course, with the Guzzi having a dry clutch this would not be an issue. Whilst on the subject of oil, I was also considering using one of the magnetic thingies which screws between the sump and oil filter. Is there room to fit one? It appears to be a very tight squeeze. Link to comment Share on other sites More sharing options...
John O'Sullivan Posted November 12, 2002 Share Posted November 12, 2002 Hello there, I think you already have a magentic sump stud which will take care of any metal in your oil. To the best of my knowledge most modern oils are excellent lubricants without further additives. The best advice is to change oil regularly especially if you do short rides only. I have used semi-synthetic oils in various engines for the past five years and have had no oil related problems. Regards, John in Kerry Link to comment Share on other sites More sharing options...
jrt Posted November 12, 2002 Share Posted November 12, 2002 Hey-o I use full synthetics (Mobil one, cause it's available). At 10K miles (just a few more), I'll probably start adding in the moly as well. Don't bother with slick50 or it's variants. IIRC, they're embroiled in lawsuits over false claims. Today's oil is plenty slick already- witness Carl's statements above. Actually, I wrap all my plugs with teflon too, although I don't go so far as to safety wire them (good on ya' Carl). It has caused me some concern, because I would hate the little strings of teflon to get caught in an oil port and clog it. Doh! Happened to my brother's Datsun PU, when he rebuilt it. So I CAREFULLY wrap the plugs and whatnot. Cheers, Jason Link to comment Share on other sites More sharing options...
Guest HI-TECH-CHECK Posted November 12, 2002 Share Posted November 12, 2002 I use "dino" 20w50 in the engine and Castrol synthetic in the gearbox and trans. Do yourself a favor and stay away from the SLICK 50. It uses PFTE(teflon TM) as the active ingredient. It is a suspended solid which tends to collect at inlets (oil passages) and acts as a blockage. It also collects in the oil filter and can clog it up resulting in a decrease oil pressure in your engine. For the full report see http:///www.bmwscruz.com/tech/tech003.html It will really open your eyes and close you mind to additives. Link to comment Share on other sites More sharing options...
Guest Ragin' Pit Bull Posted November 12, 2002 Share Posted November 12, 2002 I've been using AGIP 4t in the engine and Spectro full synthetic gear lube in the tranny and the rear. I have a bottle of AGIP Rotra at home that I'm going to try at 12,000 miles. Link to comment Share on other sites More sharing options...
Guest vkerrigan Posted November 13, 2002 Share Posted November 13, 2002 In my 02 LeMans, I've been using Redline 15-50 full synthetic in the engine and Redline's Shockproof Heavy full synthetic in the transmission and rear drive. The transmission shifted easier immediately upon changeout to the Shockproof Heavy. I'm sure other full synthetics lubricate effectively as well, but its like most things..............personal preference..........VK Link to comment Share on other sites More sharing options...
