WDGUZZI Posted December 27, 2024 Posted December 27, 2024 After remounting my 2002 LeMans front wheel with its new Dunlop Roadsmart 4 (please see picture for proof) and feeling like an ace mechanic for how easily it went on, I have been floundering with getting the rear wheel back on. I've reviewed the little line drawing in the owners manual and threads on this forum, and am convinced that the spacer I have on the right side of the bike between the thin flat wide washer and the swingarm should really go inside the hub assembly, between the rear end housing and the wheel where the splines engage. If this is correct, then is there really just the very thin wide washer between the right wheel bearing and the right inner side of the swingarm? Thanks for any advice on this!
audiomick Posted December 27, 2024 Posted December 27, 2024 (edited) From memory (it's while back...) the final drive more or less sits up against the swing-arm on that side. Have a look at the drawing on page 43 of this document (according to the document viewer) https://guzzitek.org/parts_list/gb/1100/V11LM_2002_062011_PL(GB).pdf and page 122 here https://guzzitek.org/gb/ma_us_uk/1100/V11_1999-2003_Atelier(Compil-GB-D-NL).pdf As I indicated, I don't remember exactly how it went back together, but I got it right by looking at those documents. Edit: the short answer is, I think your assumption about where the spacer should be, i.e. " inside the hub assembly, between the rear end housing and the wheel where the splines engage" is indeed correct. Edited December 27, 2024 by audiomick
Lucky Phil Posted December 27, 2024 Posted December 27, 2024 1 hour ago, WDGUZZI said: After remounting my 2002 LeMans front wheel with its new Dunlop Roadsmart 4 (please see picture for proof) and feeling like an ace mechanic for how easily it went on, I have been floundering with getting the rear wheel back on. I've reviewed the little line drawing in the owners manual and threads on this forum, and am convinced that the spacer I have on the right side of the bike between the thin flat wide washer and the swingarm should really go inside the hub assembly, between the rear end housing and the wheel where the splines engage. If this is correct, then is there really just the very thin wide washer between the right wheel bearing and the right inner side of the swingarm? Thanks for any advice on this! Spacer goes inside the bevel box. Phil
WDGUZZI Posted December 27, 2024 Author Posted December 27, 2024 Thank you Audiomick and Phil! And big thanks for that workshop manual. I only had an owners manual. 1
docc Posted December 27, 2024 Posted December 27, 2024 1 hour ago, WDGUZZI said: After remounting my 2002 LeMans front wheel with its new Dunlop Roadsmart 4 (please see picture for proof) and feeling like an ace mechanic for how easily it went on, I have been floundering with getting the rear wheel back on. I've reviewed the little line drawing in the owners manual and threads on this forum, and am convinced that the spacer I have on the right side of the bike between the thin flat wide washer and the swingarm should really go inside the hub assembly, between the rear end housing and the wheel where the splines engage. If this is correct, then is there really just the very thin wide washer between the right wheel bearing and the right inner side of the swingarm? Thanks for any advice on this! Yes, indeed, the thin washer stays outboard of the right side needle cage that abuts the right side swingarm. Grease that needle assembly and thin washer liberally (with every tire change)! The spacer fits on the axle between the inboard rear drive bearing and the inboard wheel bearing, within the hub drive interface . . . 2 1
billgreenman1 Posted December 27, 2024 Posted December 27, 2024 Yep I put it together wrong once also, thinking "what is wrong?" Then feeling both silly and victorious once it went together properly. The rear fender also was a bit of a struggle too. 2
guzziart Posted Wednesday at 09:17 PM Posted Wednesday at 09:17 PM (edited) Fwiw, I found that outboard washer between the internal/external drive spline assembly. Since I had bought the lemans from a riding pal of mine (original owner) I asked him if he had the wheels off last, he told me a shop had did the work. I'm just glad nothing got damaged or that nothing locked up on me while riding . However, it was evident that with the washer in there only half of the splines were engaged. The only reason I was rooting around in there was because the bike had not been rode in a few years and I wanted to be sure the drive & drive shaft splines were lubed and not rusted. I don't know how a shop thought to toss the washer in there since the washer ID is waaaay larger than the axle OD. Oh well. Edited Wednesday at 09:18 PM by guzziart 2 1
