XELOS17 Posted 16 hours ago Posted 16 hours ago Hello and sorry if the translation is not clear but I do not speak English and I use Google for that. I am looking for reliable springs because the only French dealer has died. New owner of a V11 le mans rosso corsa from 2005 I learned about the problem of the machine and read on your forum the means of repair, I only need one or two springs to finalize the problem of selector as a preventive measure. If anyone knows where I can get it......Thanks in advance and good luck to all Sincerely 2
gstallons Posted 16 hours ago Posted 16 hours ago Please explain which spring you are looking for ? Can you tell us if it is inside the shift cover ? Maybe someone can post a diagram and you can identify it.
Chuck Posted 16 hours ago Posted 16 hours ago It sounds like the selector spring. @Scud on this list has them. 2
docc Posted 13 hours ago Posted 13 hours ago 3 hours ago, XELOS17 said: Hello and sorry if the translation is not clear but I do not speak English and I use Google for that. I am looking for reliable springs because the only French dealer has died. New owner of a V11 le mans rosso corsa from 2005 I learned about the problem of the machine and read on your forum the means of repair, I only need one or two springs to finalize the problem of selector as a preventive measure. If anyone knows where I can get it......Thanks in advance and good luck to all Sincerely Welcome @XELOS17! In addition to sourcing the selector spring from @Scud, perform Lucky_Phil's shift improvement: 2
p6x Posted 13 hours ago Posted 13 hours ago 3 hours ago, XELOS17 said: Hello and sorry if the translation is not clear but I do not speak English and I use Google for that. I am looking for reliable springs because the only French dealer has died. New owner of a V11 le mans rosso corsa from 2005 I learned about the problem of the machine and read on your forum the means of repair, I only need one or two springs to finalize the problem of selector as a preventive measure. If anyone knows where I can get it......Thanks in advance and good luck to all Sincerely Si tu as des difficultés pour comprendre, il y a des membres Français du forum qui peuvent t'aider. Tu dois donc contacter @Scud qui possède des ressorts de remplacement qui sont plus solides que les originaux. L'administrateur du Forum the propose de suivre les conseils d'un des membres techniques du forum, pour ne plus avoir le problème du ressort de rappel du selecteur cassé. Bonne chance! 2
p6x Posted 13 hours ago Posted 13 hours ago When I saw the title of the thread, I thought he was simply hoping for better weather.... 1 2
Scud Posted 12 hours ago Posted 12 hours ago I sent a private message. Still have quite a few springs left. 1 1
XELOS17 Posted 12 hours ago Author Posted 12 hours ago 47 minutes ago, p6x said: When I saw the title of the thread, I thought he was simply hoping for better weather.... 😂😂😂😂😂😂😂 1
XELOS17 Posted 12 hours ago Author Posted 12 hours ago 1 hour ago, p6x said: Si tu as des difficultés pour comprendre, il y a des membres Français du forum qui peuvent t'aider. Tu dois donc contacter @Scud qui possède des ressorts de remplacement qui sont plus solides que les originaux. L'administrateur du Forum the propose de suivre les conseils d'un des membres techniques du forum, pour ne plus avoir le problème du ressort de rappel du selecteur cassé. Bonne chance! Merci pour ce commentaire en français, j'ai contacter @scud et il m’envoie un exemplaire du fameux ressort👍, n'ayant pas encore démonté j'essaye de comprendre l'astuce de Lucky_Phil's, si besoin je reviendrait vers vous. Merci
gstallons Posted 10 hours ago Posted 10 hours ago 3 hours ago, p6x said: When I saw the title of the thread, I thought he was simply hoping for better weather.... That is funny . Also thank you for being the interpreter ! 2
