Let it snow, let it snow, let it snow...
Posted (edited)
20 hours ago, Scud said:
Being the curious sort, I went to measure. If I measure from the outer tread blocks horizontally, the diameter is only about 32". However, the tread is curved and the center of the tread bulges almost 1/2" per side. I don't have a proper caliper to measure the maximum diameter, but If you were to measure the diameter at the center of the tread, I think the expected 32.8" measurement is realistic.
Generally the measurement is taken from the edge of the tread. Even still, you will get a different measurement on a mounted and installed tire if you measure side to side edge of the tread vs vertically from the ground to the top edge of the tread. That would be because the tire deforms at the contact patch, how much depends on air pressure in the tire. For general tire size measurements people tend to either measure a tire off the vehicle or measure an installed tire but measure side to side so the contact patch deformation doesn't enter into it. But when you are measuring for speedometer calibration you actually want to include that contact patch deformation, typically. So, there are times when measuring vertically from the ground to the top edge of the tire is desired.
Being about 0.8" smaller then the published size is not bad. That is probably closer then the KO2 would have been. The KO2 tended to be around an inch or so smaller than the published size.
And thanks for measuring.
Edited by GuzziMoto
10 hours ago, GuzziMoto said:
... But when you are measuring for speedometer calibration you actually want to include that contact patch ...
Without wanting to completely de-rail the thread, measuring the tyre is not the right way to go at that. One should mark the side-wall of the tyre where it touches the ground, and make a corresponding mark on the ground. Roll the vehicle forwards until the mark on the side-wall is back down to the ground, and mark the ground again. The distance between the two marks on the ground is the real rolling diameter of the tyre. :huh2:
Perhaps, but most applications I work with that allow you to calibrate a speedo for different tire sizes use diameter or radius of the tire and not circumference. Perhaps others want the rolling circumference, but not ones I work with. My Jeep, for example, uses diameter. To get my 37" BFG KO2s to read the right speed and miles I had to enter a diameter of 35.25 as I recall. I have worked with bicycle speedo's that used a rolling diameter based input but I have not used rolling diameter for any automobile application I have worked with.
  • 1 month later...
Posted (edited)
A video that seems to be dealing with facts rather than illusions;
I have my Ford Transit Connect equipped with all season tires, because in Texas, you need to be prepared for anything nowadays....
This review is excellent, even if missing the autonomy/durability concept.
Edit: Found a review that states the wear out distance;
Edited by p6x
Why would you want to go through all that? Why calibrate a speedo? All three of my cars the speedos over read different amounts. The Kia 5kph@100, the Mazda 2kph@100 and the Supra 2kph@100. All calibrated off the GPS. I adjust the cruise control speed accordingly and I know at lesser speeds the difference is even smaller. Seems to me when you fit significantly different wheel sizes you just do a 60 mph drive and check it against the GPS and remember the offset and you're good. Even with my addled brain I can remember the speedo inaccuracies in three different cars. Add to that a motorcycle with a Veglia speedo!
Phil
  • Haha 2
Happy I grew up with with not much concern about speed limits, FOR sure.
Ah well, Good Friday guys.
Cheers Tom.
4 hours ago, Lucky Phil said:
... All three of my cars the speedos over read different amounts....
Of course. The law in Australia and in Germany, and probably most other countries, stipulates that the speedo must not show less than the actual speed. Over-estimating is fully legal, and the norm. One can assume that up to 10% over-estimation is normal. The only speedo that I have experienced that is almost accurate, i.e. almost no over-estimation, is the one on my Breva 750. It is only a km or so over at 60 km/h, and maybe 3 at 100 km/h.
Why go to the trouble? Calibrating against the GPS is the logical solution. Easy, and easy to remember for multiple vehicles. But if one is installing a new speedo and wants to calibrate it, one must measure something to get a "base value". The method described is the best way to establish the real rolling diameter of the tyre, and therefore the base-value to calibrate the speedo. I've done it a couple of times with push-bike speedos. Takes all of 3 minutes. :huh2:
Posted (edited)
15 minutes ago, docc said:
And changes as the tires wears?
Will mean that the speedo over-estimates, so legal.
But a meticulous owner would of course regularly check the wear on the tyres, and correct the calibration of the speedo as needed.
Or maybe just consider the idea, and have a beer instead. :huh2:   :grin:
Edited by audiomick
  • Haha 2
Pop quiz! :nerd:
A) a meticulous would of course regularly check the wear on the tyres
B )  correct the calibration of the speedo as needed.
C) both A and B
D) Or maybe just consider the idea
E) and have a beer instead.
F) both D and E :sun: :bier:
