2 minutes ago, Steve Swan said:
@docc what is Klüber Staburags?
Amazing, sticky tooth-mesh ("pressure angle" :sun:) grease. Doesn't fling off the hub like my (otherwise trusted) BelRay WaterProof grease.
[representative image. The squeamish should avert their eyes] . . .
Posted (edited)
13 minutes ago, docc said:
Nope,  That's a fail.  We've had 2 failures of those.  Mine and some else's.  They leak, like a razor cut in the hose at the bend.  Some disappointment regarding MG here as well.
Had to go to O'Rielly's and kluge some universal hoses.  Much cheaper too.  It's not a simple task to install either.
Do a search here and you'll get the full story.
Edited by LowRyter
  • Sad 1
37 minutes ago, Steve Swan said:
I was thinking if i could get away with cutting off the degraded piece of hose and reconnecting...:grin:  Where can i source a new one?
Don't try and save it. It's degraded all the way along, and the other end is likely to be not far off the state of the end in the picture.
I bought one about a year ago, so they are available. I think I got mine from Stein-Dinse. If I remember rightly, I also found a cheaper one there, but was strongly advised by knowledgable and experienced people to get the expensive one, or plan on replacing it again in a couple of years. It's a bit of a pain to get to, so I bought the expensive one. B)
If Stein-Dinse has it, I expect that the better suppliers in the USA would also have them.
https://www.stein-dinse.com/en/item-1-1116274.html
30157400_g.jpg?1668313897324
This pic must be a gag!  I practiced as a nurse for 45 years, started out in in a busy K.C. trauma E.R.  How are you infusing what i assume is grease via clear plastic tubing into the U-joint? Not!?
  • Haha 3
A ruse on how hard it has been to grease the front U-joint on the V11 SpineFrame driveshaft.
All a person has to do is take the whole apart and those zertks are really easy to get to.
  • Haha 2
Any MG dealer has/can get these . get two and have a standby. The grease is a brand / type of grease. Everyone has their preference .
Posted (edited)
Picking up on the swingarm bearings...
I have replaced two sets of those, and they were sealed bearings. I didn't think they could be opened up, cleaned and re-packed. And these are double-row (extra thick) bearings, so I'd be surprised if you could service both rows. But I'm open to learning if this can be done.
If you decide to replace them:
Removal... an electric heat gun is useless here. You will need a proper torch and a heavy slide hammer with the swingarm well secured. You can probably borrow/rent a slide hammer from an auto parts store (especially if you  buy a pair of bearings from them).
And for putting them back in - freeze the bearings (in a zip lock bag to prevent moisture from getting in), heat the swingarm with the aforementioned torch. Grease it all up, and pound them in with a proper bearing installation tool - or just take it to a machine shop and have them pressed in.
Edited by Scud
  • 2 weeks later...
Posted (edited)
Today i gave the poor old sow a bed bath... first step to making at the least as faux silk purse...:lol: apology for siedeways pic,  took the damn thing in vertical with camera phone, and rotated 90 degrees x's 4 to get it upright, ain't happenin'
Edited by Steve Swan
  • Haha 1
23 hours ago, Steve Swan said:
... get it upright, ain't happenin'
Get GIMP. B)
  • 1 month later...
Upate to revitalizing this LeMans.
I have the rear end back together.  i was able to remove the retainers for the 2-row swing arm bearing, wash them out with brake cleaner, and then blow them clean with 120 psi, grease the balls bottom and top, reinstall retainers, reinstall seals.
i am now at the place where the wheel alignment needs to be adjusted and set. Your shared expertise to set the alignment will be appreciated.
Prior to dismantle, threads of RH pin protruded 7 tread; right 6 threads. Threading in the pins, turning RH pin in to expose 7 threads, the LH pin threaed in to 4  thrreads exposed, not the 6 treads exposed.
Attached are pics of tihis stage completed.
