docc Posted February 12 Posted February 12 2 minutes ago, Steve Swan said: @docc what is Klüber Staburags? Amazing, sticky tooth-mesh ("pressure angle" ) grease. Doesn't fling off the hub like my (otherwise trusted) BelRay WaterProof grease. [representative image. The squeamish should avert their eyes] . . . 2
docc Posted February 12 Posted February 12 15 minutes ago, Steve Swan said: @docc what is Klüber Staburags? I was thinking if i could get away with cutting off the degraded piece of hose and reconnecting... Where can i source a new one? GU30157400 https://www.mgcycle.com/index.php?main_page=product_info&cPath=71&products_id=1186 1
LowRyter Posted February 12 Posted February 12 (edited) 13 minutes ago, docc said: GU30157400 https://www.mgcycle.com/index.php?main_page=product_info&cPath=71&products_id=1186 Nope, That's a fail. We've had 2 failures of those. Mine and some else's. They leak, like a razor cut in the hose at the bend. Some disappointment regarding MG here as well. Had to go to O'Rielly's and kluge some universal hoses. Much cheaper too. It's not a simple task to install either. Do a search here and you'll get the full story. Edited February 12 by LowRyter 1
audiomick Posted February 12 Posted February 12 37 minutes ago, Steve Swan said: I was thinking if i could get away with cutting off the degraded piece of hose and reconnecting... Where can i source a new one? Don't try and save it. It's degraded all the way along, and the other end is likely to be not far off the state of the end in the picture. I bought one about a year ago, so they are available. I think I got mine from Stein-Dinse. If I remember rightly, I also found a cheaper one there, but was strongly advised by knowledgable and experienced people to get the expensive one, or plan on replacing it again in a couple of years. It's a bit of a pain to get to, so I bought the expensive one. If Stein-Dinse has it, I expect that the better suppliers in the USA would also have them. https://www.stein-dinse.com/en/item-1-1116274.html 2
Steve Swan Posted February 12 Author Posted February 12 1 hour ago, docc said: Amazing, sticky tooth-mesh ("pressure angle" ) grease. Doesn't fling off the hub like my (otherwise trusted) BelRay WaterProof grease. [representative image. The squeamish should avert their eyes] . . . This pic must be a gag! I practiced as a nurse for 45 years, started out in in a busy K.C. trauma E.R. How are you infusing what i assume is grease via clear plastic tubing into the U-joint? Not!? 3
docc Posted February 12 Posted February 12 46 minutes ago, Steve Swan said: This pic must be a gag! I practiced as a nurse for 45 years, started out in in a busy K.C. trauma E.R. How are you infusing what i assume is grease via clear plastic tubing into the U-joint? Not!? A ruse on how hard it has been to grease the front U-joint on the V11 SpineFrame driveshaft.
Steve Swan Posted February 12 Author Posted February 12 9 minutes ago, docc said: A ruse on how hard it has been to grease the front U-joint on the V11 SpineFrame driveshaft. All a person has to do is take the whole apart and those zertks are really easy to get to. 2
gstallons Posted February 12 Posted February 12 Any MG dealer has/can get these . get two and have a standby. The grease is a brand / type of grease. Everyone has their preference .
Scud Posted February 13 Posted February 13 (edited) Picking up on the swingarm bearings... I have replaced two sets of those, and they were sealed bearings. I didn't think they could be opened up, cleaned and re-packed. And these are double-row (extra thick) bearings, so I'd be surprised if you could service both rows. But I'm open to learning if this can be done. If you decide to replace them: Removal... an electric heat gun is useless here. You will need a proper torch and a heavy slide hammer with the swingarm well secured. You can probably borrow/rent a slide hammer from an auto parts store (especially if you buy a pair of bearings from them). And for putting them back in - freeze the bearings (in a zip lock bag to prevent moisture from getting in), heat the swingarm with the aforementioned torch. Grease it all up, and pound them in with a proper bearing installation tool - or just take it to a machine shop and have them pressed in. Edited February 14 by Scud 1
Steve Swan Posted February 26 Author Posted February 26 (edited) Today i gave the poor old sow a bed bath... first step to making at the least as faux silk purse... apology for siedeways pic, took the damn thing in vertical with camera phone, and rotated 90 degrees x's 4 to get it upright, ain't happenin' Edited February 26 by Steve Swan 1 1
audiomick Posted February 27 Posted February 27 23 hours ago, Steve Swan said: ... get it upright, ain't happenin' Get GIMP. 1
Steve Swan Posted Monday at 07:08 PM Author Posted Monday at 07:08 PM Upate to revitalizing this LeMans. I have the rear end back together. i was able to remove the retainers for the 2-row swing arm bearing, wash them out with brake cleaner, and then blow them clean with 120 psi, grease the balls bottom and top, reinstall retainers, reinstall seals. i am now at the place where the wheel alignment needs to be adjusted and set. Your shared expertise to set the alignment will be appreciated. Prior to dismantle, threads of RH pin protruded 7 tread; right 6 threads. Threading in the pins, turning RH pin in to expose 7 threads, the LH pin threaed in to 4 thrreads exposed, not the 6 treads exposed. Attached are pics of tihis stage completed. 4
docc Posted Monday at 09:44 PM Posted Monday at 09:44 PM Well done, @Steve Swan! Thanks for the updates! After much consternation, consideration, laser alignment, then measuring the offset on numerous V11 at a South'n SpineRaid, I decided to make my pins the same each side by turning them in to seat and relieving each by a nudge so as to have no lateral load on the bearings. YMMV. 3
audiomick Posted Monday at 10:37 PM Posted Monday at 10:37 PM (edited) @Steve Swan bear in mind that some people have a spoked in rear rim offset by as much as 5 mm, or more, to accomodate a wider rim. That seems to work without trouble, although I can't imagine that a really good rider might not notice it. What I'm getting at: putting the swing arm back in the way it was is a good plan, but on an old, second-hand bike there is no garauntee that the adjustment was really accurately correct. Put it back in, @docc 's suggestion works for me, and ride it and see how it handles. If you want to be sure, pull a bit of string past the back wheel such that it touches the back wheel front and back on both sides, but isn't bent out of true by that, and measure the distance from the string to the front wheel, both sides front and back. Take your time, and repeat the measurements a few times. That should tell you if your front and back wheels are aligned, and what you might have to do with the pins to get them aligned if they are not. Edited Monday at 10:38 PM by audiomick 2
Steve Swan Posted yesterday at 02:37 AM Author Posted yesterday at 02:37 AM Thanks @docc and @audiomick for your replies. To clarify, i will set the RH pin at its original 7 threads exposed and then turn the LH pin in for contact, then turn it out between 1/16 to 1/8 turn. I'll forgo the string and once the beast is back on the road, do a few hands off test drives. 2
