audiomick Posted February 28 Posted February 28 6 minutes ago, Lucky Phil said: ... set of thread gauges... What I use, too. I bought the vernier calipers because I wanted one, and the thread gauges came with the tap and die set, one of the best buys amongst my tools. I've had so much use out of it. Anyway, @Lucky Phil how does the 3-wire and micrometer method work? 1
Lucky Phil Posted February 28 Posted February 28 29 minutes ago, audiomick said: What I use, too. I bought the vernier calipers because I wanted one, and the thread gauges came with the tap and die set, one of the best buys amongst my tools. I've had so much use out of it. Anyway, @Lucky Phil how does the 3-wire and micrometer method work? 3 small wires that sit in the thread pitch dia, so in the thread valleys so to speak. Two on one side and one on the other and then use a std mike to measure the bolt dia. Useful when single point cutting on a lathe. This is better than my explanation. 1
gstallons Posted March 1 Posted March 1 I bought these primarily for the nuts. I have pans of standard / metric nuts and I like to go the easy and most accurate way of doing this . I was using bolts to measure thread pitch , etc. of ea. nut 2
