Lucky Phil Posted March 9 Posted March 9 I'm mulling over one of these. Shipping is the killer. https://modernspare.com/product/2019-2024-toyota-supra-spare-tire-kit-options/ 1
audiomick Posted March 10 Posted March 10 2 hours ago, Lucky Phil said: I'm mulling over one of these. The important question is, when did you last have a flat tyre? My current car doesn't have a spare tyre, as did the one before. I did have a flat with the one before: I clipped a traffic island and ripped a 4 inch hole in the sidewall of the left rear tyre. My mistake. That was more than ten years ago. Otherwise, I haven't missed or needed a spare. The current car has, and the last car had, an electric tyre pump and a can of "instant fix". If the flat on the last car had been less catastrophic, that would have been enough to get me home. I fully understand wanting to have a proper spare in the car, but the question about how really necessary it is must be asked.
stewgnu Posted March 21 Posted March 21 i’m thinking of the various times my v11 conked out and left me stranded: Toasted the battery once, toasted the rear brake, reg/rec failed, a rose joint snapped on the torque arm, gearbox spring snapped, tps went so out of whack i gave up, relay failed, rubber inlet boot developed an issue X 6 (damn those things), kill switch killed itself, alternator solder joint broke so drained battery, lost my lights once- in the dark and when it had started to snow, click no start was a fun one for a time, me left boot has been nicely coated in oil a couple of times too.. err.. that might be it..? But yeah, I carry a 10mm + 13mm spanner, 4, 5 and 6mm allen key, 4 spare relays, set of fuses, few bulbs. Most of which weren’t a deal of help. So I had to get me van. 😠 But Thank All that is Heavenly for v11lemans.com 2
gstallons Posted March 21 Posted March 21 The only crummy experience I had was coming back from Anna, Il. at night and my l.h. valve cover gasket let go and had about 1 qt of oil on my left side soaking my BRAND new boots/brand new Levis by the time I got home . I didn't know that much oil could come out of a valve cover 1 2
p6x Posted March 27 Author Posted March 27 Coming back to this topic, I remember that in the 70's, when I started riding (in France), you did not really need to worry about carrying tools with you, for each and every gas station carried just about anything you needed; spark plugs, tools, consumables, tubes. They actually would fix your flats on the spot. Free air of course, and they would also change your oil if you needed it. Batteries and what not. Today's gas station here are more grocery stores with gas pumps. You can still find oil. But the original purpose of taking care of your vehicle is different. 1
docc Posted March 27 Posted March 27 Ah, the "service station" of yore. As opposed to today's "convenience store" where you can conveniently buy fuel et cetera. 2
Skip Posted March 27 Posted March 27 I remember in 69 and 70 While still in high school I worked at a Standard Oil service station I thought I was the cats meow with my own uniform and Embroidered name on the shirt. We would always hurry out and pump the gas clean the windshield Check the oil Yes those were the days of yore. 3
stewgnu Posted Monday at 03:49 PM Posted Monday at 03:49 PM On 3/27/2025 at 1:16 PM, p6x said: Coming back to this topic, I remember that in the 70's, when I started riding (in France), you did not really need to worry about carrying tools with you, for each and every gas station carried just about anything you needed; spark plugs, tools, consumables, tubes. They actually would fix your flats on the spot. Free air of course, and they would also change your oil if you needed it. Batteries and what not. Today's gas station here are more grocery stores with gas pumps. You can still find oil. But the original purpose of taking care of your vehicle is different. Y’know it wasn’t that long ago when most fuel stations in the uk had a tyre pumper compressor inflator pumper. They were free initially, then were 20p, then 50p, then a quid. Then they were always busted, and now they’re all dodo likes. ☹️ I recently saw an esso, or shell or whatever evil corp, advertising that correct air pressures in ones tyres will increase efficiency, help the environment (!) and swell your prick magnificently. 😬 3
gstallons Posted Monday at 08:22 PM Posted Monday at 08:22 PM What kind of adapter goes for the prick inflator ? i would like to see the pressure readings before doing ANYTHING down there 1 1 1 1
p6x Posted Monday at 10:47 PM Author Posted Monday at 10:47 PM 6 hours ago, stewgnu said: They were free initially You still get free air on every gas station on the highways in France. They also have rest areas, with tables, so you can take a break and relax a little bit. None of the gas station around me have that. And yes, free air does not exist at gas station, you needed four quarters to inflate, with most of those stations out of order. There is an exception, though. Costco offers free air to anybody. So you can as it was meant to, fill your tan and check your tire pressure.
p6x Posted Monday at 10:48 PM Author Posted Monday at 10:48 PM 2 hours ago, gstallons said: What kind of adapter goes for the prick inflator ? They don't use air, but fat from your love handles to inflate it. 1 2 1
gstallons Posted Tuesday at 10:48 AM Posted Tuesday at 10:48 AM So far this doe not hold true above the Equator .
