docc Posted 21 hours ago Posted 21 hours ago Just the "stick"/ #1 : SIDE STAND (#01432190), or some/all of the whole Rube Goldberg mechanism? All sidestands were the same throughout the 1999-2005 V11 SpineFrame range?
audiomick Posted 21 hours ago Posted 21 hours ago (edited) 35 minutes ago, docc said: All sidestands were the same throughout the 1999-2005 V11 SpineFrame range? Maybe not. The parts lists at Wendel in Berlin show a change in the part number, at least for the "stick", around 2002. Subsequent lists refer to "Seitenständer V11 neu", i.e. "sidestand V11 new". The first version, part no. GU02432100 https://wendelmotorraeder.de/fussrasten-v11-sportmandello-99-01-ex-30_3006_300602_30060201_3006020110_300602011003.html https://wendelmotorraeder.de/fussrasten-v11-nakedle-manns-01-02-ex-30_3006_300602_30060202_3006020210_300602021003.html and the new version, part no. GU01432190 https://wendelmotorraeder.de/fussrasten-staender-v11-02-le-mansskura-ex-30_3006_300602_30060203_3006020310_300602031003.html https://wendelmotorraeder.de/fussrasten-staender-v11-03-04-corsa-ex-30_3006_300602_30060204_3006020410_300602041003.html https://wendelmotorraeder.de/fussrasten-staender-v11-03-05-cafballabio-ex-30_3006_300602_30060205_3006020510_300602051003.html However it seems that the new version might fit on the earlier models. Stein-Dinse only lists the newer part number. There is a comment in the list and in the listing in their shop "Nachfolgeprodukt für Artikel: 02432100", i.e. "replacement product for article: 02432100" https://www.stein-dinse.com/de/moto-guzzi-seitenstaender-v11-le-mans-naked-ballabio/item-2-1020771-01432190-.html and under "Geeignet für" i.e. "suitable for" they list pretty much all the V11 Models. The thlot pickens.... Edited 21 hours ago by audiomick 1
docc Posted 18 hours ago Posted 18 hours ago Anyone with early and later V11s that could compare the sidestands, er "side-by-side" ?
Tomchri Posted 18 hours ago Posted 18 hours ago No measurement, looks the same. Black colored, looks different, sure the same. Cheers Tom. Sent fra min SM-S906B via Tapatalk 2
audiomick Posted 17 hours ago Posted 17 hours ago 6 minutes ago, Tomchri said: ... Black colored, Ahh, I wondered about the colour. A different colour alone would explain the different part number, even if it is actually physically the same part. 1
gstallons Posted 14 hours ago Posted 14 hours ago 10 hours ago, Randy said: I need a V11 kickstand, 2003-04. Please include a little more information 1
activpop Posted 13 hours ago Posted 13 hours ago Looked closely and measured both the 04 and the 01. Looks the same to me. 1
activpop Posted 13 hours ago Posted 13 hours ago Geez @Tomchri, when you gonna clean those things... 1
Chuck Posted 3 hours ago Posted 3 hours ago 9 hours ago, activpop said: Geez @Tomchri, when you gonna clean those things... Yeah, they are pretty rough all right. Just a heads up if anyone hasn't noticed that they wear away on the back side. I made up a stainless "shoe" that fit over the Mighty Scura's foot and epoxied it on. 2
Pressureangle Posted 25 minutes ago Posted 25 minutes ago (edited) 3 hours ago, Chuck said: Yeah, they are pretty rough all right. Just a heads up if anyone hasn't noticed that they wear away on the back side. I made up a stainless "shoe" that fit over the Mighty Scura's foot and epoxied it on. I discovered while adding a hardened bolt to the heel of mine that there's a steel core cast inside the leg. Too bad they didn't make it a steel foot. Seems like they're hen's teeth- what happened? Is your mounting bracket ok? Edited 16 minutes ago by Pressureangle
