1 minute ago, Randy said:
In particular I need the mounting bracket. Item 2 on the drawing. I'll take the whole assembly as well.
If the bracket has been bent, there is potential for damage to the attachment into the sump spacer of the smaller, bottom fastener. Inspect carefully.
Also, the larger, upper fastener that threads into the timing chest is torqued to an astounding 70 Nm. Both of these fasteners tend to loosen over time and benefit from periodic checking and, perhaps, a threadlocking agent, IMCO.
That is better. is this NLA from a dealership ?  Maybe someone has one and can help you out .
GU01433400 for the early Sports, 1999-2001.
I get the same number for the bracket from my 2002 Parts Catalog: 01 43 34 00
When searching, sometimes the "GU" is helpful, and otherwise should be left off.
When you do get this in and go to put it together , lubricate the pivot w/grease . This will make it easier and last longer.
Got one! Ebay.
