Hi all newbie here, I had a low speed fall a few months back breaking my toes and knee cap.  My toes broke the gear lever which I’ve replaced 👍
my question really is the rear subframe slightly set more to the right as you look from behind the bike ?
looking at the workshop manual it does look that way.  I’ve got new exhaust foot peg hanger for the left side as well as a new subframe if needed. The foot peg bracket looks straight and the mounting points also look to be ok and not bent.
Ok ! If it looks bent , it probably is bent . take your tape measure and measure and start looking. Verify 1
The frame dimensions are shown in dimensional drawings in the workshop manual. Unfortunately, I'm not near mine right now.
Welcome, @Paul57!
[Watch for this topic to move to Technical Topics (just housekeeping).]
Mine's apart but with the trans and swingarm out; it appears that the subframe is symmetrical along the frame spine axis.
  • Like 3
I see from the frame diagrams in the Workshop Manual that the rear tail section support subframe is very slightly asymmetric, i.e. 1.0 cm offset.
Expand
Mine still has the little plastic bit under the end of it attached, I'll see tomorrow about removing it and trying to get an accurate measure to some meaningful points, or a clearer eye view at least.
