Guest jerroldt Posted July 21, 2004 Posted July 21, 2004 I was going to drop the sump pan for the first maintenance period and then thought what the heck! I don't take the oil pan off my truck or my car when I change oil. I ordered a pan gasket and may use it at about 6K miles when I clean the crud from the pan. Anyway I bought a bolt with a 1 1/16 hex head and ground the flats to 27MM and then drilled a hole in it for a screwdriver or 1/4 inch socket extention.
jrt Posted July 21, 2004 Posted July 21, 2004 Is that electrical tape wrapped around the threads and the head? Interesting solution! I'm a little concerned that it might not be 'beefy' enough for the job, though J
twhitaker Posted July 21, 2004 Posted July 21, 2004 The big hex nut on your rear axle is the right size for the "manhole cover" and you have a box wrench in your tool kit. The two work together quite nicely. 2
Guest northend Posted July 22, 2004 Posted July 22, 2004 The two sided cheapy socket that comes with the tool kit that I believe fits the spark plugs, also fits the "manhole" and it already has a hole in it for a screw driver
Guest Jeff Kelland Posted July 22, 2004 Posted July 22, 2004 I made a tool for mine out of a bolt also. Instead of drilling a hole, I just spun a nut on the end of the bolt and welded it in place. Plenty of beef! Just put the bolt head in the manhole cover and use a big wrench to take it out. Go easy when tightening, you can get an awful lot of leverage.
Ray Posted July 22, 2004 Posted July 22, 2004 Me too. I just put two nuts on the end of the bolt and tightened them together so they line up, then wrote "Guzzi oil plug wrench " in Sharpie pen on it. The wrench thing in my kit slips before it makes enough torque. No tool box should be without a Sharpie; great tool for touching up chipped or rubbed off paint, too. Axle nut is an elegant solution, too. Diseased minds think alike?
Guest jerroldt Posted July 23, 2004 Posted July 23, 2004 Yes, that is electrical tape on the flats. I put it on to help get a snug fit when tapping it into place and to prevent the bolt head from moving around and possibly shearing some of the aluminum from the cover. I Guzzied up the rest of the bolt with some more tape and a cap plug. Idle time!
Guest northend Posted July 23, 2004 Posted July 23, 2004 I still don't understand why you all are making tools when the one in the tool kit works fine . I guess I just wish I had that much spare time on my hands
Ray Posted July 23, 2004 Posted July 23, 2004 Maybe we should compare the contents of the '03 vs '00 tool kits - start a thread? That would be a good use of time...
twhitaker Posted July 23, 2004 Posted July 23, 2004 Me too. I just put two nuts on the end of the bolt and tightened them together so they line up, then wrote "Guzzi oil plug wrench " in Sharpie pen on it. The wrench thing in my kit slips before it makes enough torque. No tool box should be without a Sharpie; great tool for touching up chipped or rubbed off paint, too. Axle nut is an elegant solution, too. Diseased minds think alike? The axle nut is like your American Express. You don't leave home without it. If you do you are going to have problems down the road.
Cabernet Posted October 22, 2024 Posted October 22, 2024 On 7/21/2004 at 11:59 PM, twhitaker said: The big hex nut on your rear axle is the right size for the "manhole cover" and you have a box wrench in your tool kit. The two work together quite nicely. I have been pondering if this would be the case for a week now. Thanks! 1
