Ignition Button
Guest V11Cowboy
My 2003 V11 LeMans has done this for a year. I thought it was the kill switch, thought it was the clutch switch. Dealer thought it was kill switch and replaced under warranty. Problem reapeared off and on. I removed the tank and found bullet connectors on the wires from the clutch switch were loose. I could move them slightly in and out and get go/no go. I cleaned them, applied dialectric grease, and recrimped them tighter. 6 months now no problem
Thanks, Jason and Roberto, for the advice! I'll clean off the battery and check my connections first to see if that's not the problem and save cleaning the solenoid for later.
joshua
Roberto. I think you have been lurking at the pelican parts r1100s forum. I read that article on the valeo starter too.
