Guest CafeRacer Posted August 15, 2004 Share Posted August 15, 2004 To anyone who has successfully installed the Ferracci fender eliminator I ask: Which wires go to what? I've got a Blue with Red a Yellow and a Black on the Bike end and a Blue, Yellow and Green on the taillight end. The Blue with Red and the Blue seem to light up the light brightly when the brake lever is pulled, but I can't seem to get it to glow dimly when the bike is simply on. Help! Ben Link to comment Share on other sites More sharing options...
Guest callithrix Posted August 16, 2004 Share Posted August 16, 2004 I can empathize with your confusion. First buy some some 5amp (yellow) Fuses just in case you accidentally short the circuit. The hookup procedure that worked for me is the following; Blue FBF wire to the red/ blue guzzi wire, Yellow FBF wire to Yellow Guzzzi wire and Green FBF wire to Black Guzzi wire. You may have to changethe connecters and since the FBF tail light is pretty weak you may want to add an auxilllary LED light bar from JC whitney or local car supply source and set it up for either continous lighting or as an auxiallry brake tail light. Best of luck. Link to comment Share on other sites More sharing options...
robbiekb Posted August 16, 2004 Share Posted August 16, 2004 Yeah i actuall yahd a similar "moment" when i wired mine Luckily as i dissasembled the old fender, i labelled the wires as i took em off Link to comment Share on other sites More sharing options...
callison Posted August 16, 2004 Share Posted August 16, 2004 Link to comment Share on other sites More sharing options...
Guest Neronut Posted August 16, 2004 Share Posted August 16, 2004 I must be wrong, but it looks to me like the right front signal(green wire) light is wired to the left rear signal. And of course, the left front (pink wire) to the right rear signal in the drawing. Link to comment Share on other sites More sharing options...
callison Posted August 17, 2004 Share Posted August 17, 2004 Good grief!!! You're absolutely right! And guess what? It's like that on the original schematic I have as well as the one for the 2004 catalytic model. This is why it's invaluable to have others spot these mistakes so I can fix them. Moto Guzzi sure doesn't seem to catch these errors... Thanks. I'll fix them soon. Link to comment Share on other sites More sharing options...
callison Posted August 21, 2004 Share Posted August 21, 2004 This just got posted to the world (3 other boards), but Neronut deserves the credit for spotting the error. Try as I might, I can't catch every error the first time out. It has been pointed out to me that the turn signal wiring on the schematics for the two variants of V11 Sport that I have posted on my web page are incorrect. They have been corrected and if you've downloaded them in the past, you should replace them with the corrrected version. BTW. The errors are on the original schematic, so all I did was repeat them. My thanks to the sharp eyed afficionados at the v11lemans.com web site. Now, will someone with a 2004 V11 Sport tell me whether MG has REALLY left the generator light off of the new models? It sure isn't on the schematic I used to draft from. Left and Right turn signals instead. Maybe this is progress... http://home.pacbell.net/guzzi007/schematic...9_V11_sport.gif http://home.pacbell.net/guzzi007/schematics/2004_EV.gif Link to comment Share on other sites More sharing options...
Mr. Bean Posted August 21, 2004 Share Posted August 21, 2004 Yup, My Ballabio does not have a generator light. Instead the center row from top down is...High beam, Oil, Neutral, and Fuel. It has both right and left indicator lights as well. Randy Link to comment Share on other sites More sharing options...
robbiekb Posted August 21, 2004 Share Posted August 21, 2004 just as well, seeing as the generator light on my 2001 only works when it feels like it Link to comment Share on other sites More sharing options...
