Guest socket Posted September 27, 2004 Posted September 27, 2004 I was wondering if anyone has milled thier heads for more compression and if so who did it?
al_roethlisberger Posted September 27, 2004 Posted September 27, 2004 I don't want to say "you can't do it"..... mostly because I am not an expert in this area But when I talked to Mike Rich about this a while back, he said it is possible(he milled mine a tad, maybe getting .2-.25cr increase as part of his head porting job), but only to a small degree before you start messing up the squish-band, introduce problems with interference(valves hitting things), and add a lot of complication. In then end the results aren't worth the trouble. It's far easier to get different pistons. At least that's what I've been told al
helicopterjim R.I.P. Posted September 28, 2004 Posted September 28, 2004 I have FBF suposed 11:1 pistons. They are way too much fun but thanks for being at straubing=S Want to see you on the the taiga. Woe ist die target?
