Steve G. Posted October 10, 2004 Posted October 10, 2004 Just checking to see if my new oil line is free of leaks, and thought I'd check all the other ones. I found one of the lines had sawed it's way into the front of the engine, as a result of Luigi not routing it correctly at the factory. Do yourself a favour and check the oil line off the left [clutch lever] side of the oil cooler, as it finds it's way into the front of the engine area, see that it isn't touching the engine, and slowly cutting into it. Ciao, Steve G.
Guest Brian Robson Posted October 10, 2004 Posted October 10, 2004 I found that one too, as well as the one touching the alternator cover. Very effective saw is that SS line!
