joe camarda Posted October 12, 2004 Posted October 12, 2004 The fuel line from the left bottom tank...does it route 1. Over the throttle cable? 2. Under the throttle cable, but over the metal brace rod? 3. Under the metal brace rod? As always, TIA, Joe
al_roethlisberger Posted October 13, 2004 Posted October 13, 2004 I don't think it matters so much, although your goal should be to keep it away from any moving or abrasive parts... or in general avoid contact with anything that might rub through over time. And you should try to route the line as far from heat as possible. I've had fuel lines running all over this bike, so it doesn't really matter as long as the criteria above are met. al
Guest Brian Robson Posted October 13, 2004 Posted October 13, 2004 Mine goes under the cable, brace rod and spark plug lead.
joe camarda Posted October 13, 2004 Author Posted October 13, 2004 Al and Brian, Thanks. Youre a great bunch of Chaps!
