'04 Lemans oil leak question
Hi - My 04 V11 Lemans has been leaking oil somewhere on the left side. The left side of the air intake box is always wet with a thick layer of oil and it drips down onto the engine left side. I pulled the filter and the inside of the air box is dry. There is a banjo fitting that bolts into the frame just forward of the airbox left side. I thought that was the source. I removed, inspected, and refit and now I think that is not the source but could be wrong. What else should I look? thanks
Trying to add picture of the TOYS in the stable.
Take a look at the oil line that feeds the rocker box. Sometimes the crush washer there leaks. There is also a breather line with a hose clamp that could have worked loose.
