on the road again
just got the scura back on road yesterday. sent the shock back to OLINS they replaced the line, it blew fluid all over the place sure is nice to have my guzzi up & running. the new line is a hell of alot bigger around tight fit
Did your shock blow the line? Mine blew at the big banjo bolt going into the reservior. This was not long after the shop fixed my broken shifter spring so I figured when they were doing that they might have inadvertently strained the hose.
It was replaced under warranty.
john, all i was told was that they replaced the line i did check the banjo bolt all was tight this new hose has a new plastic shell so they must of had some trouble with this design yes they fixed this under warranty. :bier:
