Hi there,
FYI I've copied this info from the Danish Guzzi Club homepage:
________________________________________________________________
Hello,
this year we have build a new digital ignition, which replaces the MOTOPLAT-boxes or contacts.
Look here
regards
Volker Sachse (Germany)
__________________________________________________________________
Best regards
Søren
Guest aj howard
I wonder what the wise ones of the board will make of this?
Hey Pete, if you are not blasting around on your big flywheel sport/tour/munt/monster... give us your .02$ :luigi:
Cool!
It has a touring curve and a sport curve and you can adjust the timing!!!!
I am not sure if the 7900rpm kill is a good thing or not.
This unit has a wasted spark, are our coils up to the task?
How about twin pluggers like Al?
Also, why do they recommend more advance for higher compression engines?
I thought one would want less advance.
Is it better to reduce pinging with fuel than ignition?
