beauchemin Posted November 17, 2004 Posted November 17, 2004 I have an oil leak at the ignition timing pickup. I see that there is some red-coloured sealant used by the factory to seal the ignition timing pickup. Do I need to use anything special when re-sealing the pickup? Chris B.
RacerX Posted November 17, 2004 Posted November 17, 2004 I have an oil leak at the ignition timing pickup. A sealant such as Yamabond or Permatex liquid gasket is what I've used. You have to let them cure fully over-night in a heated space, but they will work. $.02 ToddGuzziTech.com
