The manual states that the transmission requires 80W/90 weight oil, but there is no mention of the minimum required grade.
Can I use Silkolene "Comp Gear" transmission oil? The grade is GL-3 & GL-4.
Chris
Chris, Personally I would go for a GL-5 myself. I am going to change mine any day now. I will be using Castrol Syntrax 75W/90 which is fully synthetic. Below is what I found on a UK website regarding Agip Gear Synth 75W/90 which is the recommended oil.
"AGIP SYNTH GEAR
SAE 75W-90
AGIP GEAR SYNTH is a part synthetic gear oil for the lubrication of gearboxes and final transmissions of bikes with particular EP characteristics (API GL-4) and an exceptional viscosity-temperature curve which guarantees high fluidity at the lowest temperatures.
API GL-4 / GL-5"
Rob
