Leaks oil. Jeez... ya think???
Never underestimate the ability of a cracked crankcase recirc hose to dump oil all over your bike at 80 mph. Try two quarts in 25 miles.
EEK! That musta made a helluva mess. Lookin' for the 5 gallon drum of S100 under the tree this year? (for you, a bar of soap will have to do). :D
With the number of complaints we've heard over the years of this hose failing from heat deterioration, etc.... I think it makes sense to perhaps make a replacement out of some of the "indestructable" high performance hoses and fittings one can get from SummitRacing.com, a local "hot rod shop", etc....
There are hoses like the blue stuff I used during my first rounds of fuel-pump relocation, that is safe to several hundred degrees, and well over 100 psi. Add a couple appropriate angle fittings... and you'll probably never have to replace this hose again.... for about $40 worth of parts probably.
al
