Skeeve Posted December 7, 2004 Posted December 7, 2004 The choke lever [o.k., o.k.; "cold start lever"] on the left handlebar of my Le Mans is: 1] Alarmingly stiff to operate 2] Despite this resistance to activation, pulls shut almost immediately after starting the engine. Is this a common problem? Is there a ready fix for this? If not, how are you supposed to get the bike to idle while you're putting on your gear: you can't just stand there holding the thing! It's new, so I could take it to a dealer & whine, but I'd rather find out if it's something simple I could do for myself before going to the bother of taking it in, as he's not close by... TIA
Cliff Posted December 7, 2004 Posted December 7, 2004 I never use it. I don't start the bike till I'm on it and ready to roll. Why don't you put your gear on first.
Steve G. Posted December 7, 2004 Posted December 7, 2004 It is a very common trait among all of these V11 based bikes. The spring they use is too thick and strong, and it does not have to be that strong. Earlier on I took the spring off, cut a section out and stretched it out, with some success. Chris Beauchemin was nice enough to mail me a spring of lighter guage which works great. Don't take it to a dealer, this is an opportunity to get aquainted with your machine. This small, but annoying little glitch with these bikes is another example of how a Moto Guzzi engineer given the responsiblity to install this "fast idle thing" must have been a real lazy bugger, to simply try out a 1/2 dozen springs of differing length and size to get the one that works. I don't know, maybe engineering in Italia is a footloose and lackluster assignment. Ciao, Steve G.
beauchemin Posted December 7, 2004 Posted December 7, 2004 See this thread http://www.v11lemans.com/forums/index.php?showtopic=3907
antonio carroccio Posted December 8, 2004 Posted December 8, 2004 If you are a little bit handy, you can adjust this from under the fuel tank.It is a 15 min work . It will be never stiff again. Never. Although, that’s what I did and it works perfect. If I turn it on, it goes up to almost 2000 rpm, just enough for the winter start. If you do not understand, I will make a photo for you and post it on this thread. ciao
Skeeve Posted December 8, 2004 Author Posted December 8, 2004 I never use it. I don't start the bike till I'm on it and ready to roll. Why don't you put your gear on first. 38472[/snapback] Because it's an inane waste of my precious time? Because riding an incompletely warmed-up machine is a fast way to a shorter lifespan [for both man & machine?] This was a trick question, right? There's gotta be dozens of correct answers as to why it's ridiculous to work around a mechanical failing that should be easy to correct....
Skeeve Posted December 8, 2004 Author Posted December 8, 2004 See this thread http://www.v11lemans.com/forums/index.php?showtopic=3907 38480[/snapback] Aha! That's just the info I needed. Thanks much!
dlaing Posted December 31, 2004 Posted December 31, 2004 For the ultimate solution checkout Skeeve's postMystery solved!, spring-sprang-sprung http://www.v11lemans.com/forums/index.php?showtopic=4206&hl= In short the guzzi factory mixed up the fast idle return spring with the seat latch return spring. Way to go Skeeve!
Guest ckamin Posted March 17, 2005 Posted March 17, 2005 Yeah, I did the swap with the seat latch return spring. Now my choke works like the old Yamaha I used to have: perfectly! It takes all of ten minutes and you don't have to go spring shopping; the replacement spring is already on the bike!
