hgravelpha@aol.com Posted December 13, 2004 Posted December 13, 2004 You can eliminate the off-throttle issue with a PCIII with the following settings from 0, 2, and 4 throttle position and the rpm increments starts at 500 rpm with increments of 250 rpm. Leave the rest alone (the way you had it set). If you have a PCIII w/o usb, just match the the following RPM range set-up. This is for any options (stucchi x-over, pipes, etc). Just try it! Throttle Position 2 4 6 0 0 0 0 0 0 0 0 0 0 0 15 0 0 5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 15 10 5 15 10 5 15 10 5 15 10 5 15 10 5 15 10 5 15 10 5 15 10 5 15 10 5 15 10 5 15 10 5 15 10 5 15 10 5 15 10 5 15 10 5 15 10 5 15 10 5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
RacerX Posted December 13, 2004 Posted December 13, 2004 You can eliminate the off-throttle issue with a PCIII with the following settings from 0, 2, and 4 throttle position and the rpm increments starts at 500 rpm with increments of 250 rpm. Leave the rest alone (the way you had it set). Just try it! So where'd you hear/experience this sillyness? Joking of course... the roll-off/on mod you listed works great for smoothing on/off throttle transitions at higher rpms (that abrupt light switch throttle input some of you have experienced). Most all of the maps I supply to folks has this mod done. You are off on your throttle percentages, but the (my personal) values are correct... They should be plugged into 0, 2 & 5%. ToddGuzziTech.com Certified PCIII Tech
