Guest gavin Posted January 12, 2003 Posted January 12, 2003 Hi all, I'm just about to put my V11 Sport into my workshop for a couple of weeks of fiddlig & tweaking (stops me being tempted to ride it on our salt covered roads!!! - I sure envy you guys in warmer climes than the UK). I'm going to look in detail at everything related to handling as I feel it has 'gone off' a bit so the questions are: Fork oil - how much & what type? Head bearings - anything out of the ordinary to know? Swing arm shaft - Ditto Rear shock - Ditto. Fuel & air filters - should these be changed? (Ok so I'm going to fiddle with everything!!) Which relays should I change? Nothing wrong so far - I think. The chassis and all its ancillaries, g/box & bevel box has done 12,000 miles and the engine unit has done 4,000 miles (replaced under warranty as the first one threw a conrod). As this is my first Guzzi any suggestions as to what to tweak/check would be appreciated. Thanks
