richard100t Posted February 7, 2005 Posted February 7, 2005 I got the bike out today & spent about ten minutes on it. Too bad I wanted more :!: Well I figured out the steering lock Man that clutch rattles in neutral :!: I hope/guess thats normal though. Like just about everyone else I need to fix the vibes in the bars. I think just some bar weights & sponge grips should be enough for my taste. Btw Where should I go to get an oil filter for the bike? Online aftermarket site? Well next time I'm going to adjust the clutch lever handle. Later gaters
Lex Posted February 9, 2005 Posted February 9, 2005 I got the bike out today & spent about ten minutes on it. Too bad I wanted more :!: Well I figured out the steering lock Man that clutch rattles in neutral :!: I hope/guess thats normal though. Like just about everyone else I need to fix the vibes in the bars. I think just some bar weights & sponge grips should be enough for my taste. Btw Where should I go to get an oil filter for the bike? Online aftermarket site? Well next time I'm going to adjust the clutch lever handle. Later gaters 42795[/snapback] I'm surprised you weren't hit with 20 options on where to get oil filters. Lots of good choices. I get the OEM filter from MG Cycle. I recommend MG Cycle for anybody without a local Guzzi shop. If you bike is under warranty running the UFI part could save you some frustration if you have a problem. Lex
richard100t Posted February 9, 2005 Author Posted February 9, 2005 I'm surprised you weren't hit with 20 options on where to get oil filters. Lots of good choices. I get the OEM filter from MG Cycle. I recommend MG Cycle for anybody without a local Guzzi shop. If you bike is under warranty running the UFI part could save you some frustration if you have a problem. Lex 42911[/snapback] Thanx for the link Lex My bike is a 2001 so its out of warranty, but it only has 400 miles on it so its still in the break in period.
