'01 V11 Sport issues
Thanks for the tip poh!
I have been waiting four weeks for my switch.
The parts guy at the Ducati, Aprillia, Guzzi shop did not have one in stock and could not find a match from a Ducati.
So, off to Radio Shack!
PS Kraz, when you test the switch, check to see if the problem is intermittent. ie. Repeat the test ten, twenty, fifty or as many times as needed.
Sometimes my switch works and sometimes it does NOT.
Carl,
Could you help me with a question. On your wiring diagram what would be connected to 44 Warning light connector? I noticed these wires under my ECU and wondered what they could be used for. I worked out that the connecter 43 was part of the ECU diagnostic system.
Thanks,
Rob
Guest KingKraz
I guess I'll have to check if the switch is bad at work then... The owner said it had a problem once and the dealer had to rewire the tail light, so I'm not positive the problem lies in the switch.
kraz
