txrider Posted March 22, 2005 Share Posted March 22, 2005 I bought a service manual when I got the LeMans thinking all the info I would need would be within those oages. Wrong! I need torque values for installing the diagonal reinforcement framework that fits behind the transmission. It has following attachments- 1. Capscrews - forward struts to both sides of engine block 2. Long crossbolt going thru transmission bottom 3. Tie in to porkchops, 2 lower and two upper l/h side. These numbers must be listed somewhere, can someone point me in the right direction? Use standard values for fastener size? Link to comment Share on other sites More sharing options...
callison Posted March 22, 2005 Share Posted March 22, 2005 This ought to get you into the ball park: TORQUE WRENCH SETTINGS Typical torque wrench settings for Moto Guzzi big twins, from the V1000G5 shop manual Description -----------------------------------------...................... Setting Bolts and studs, cylinder head-cylinder to crankcase........4-4.2 kgm (29-30 ft/lbs) Spark plugs................................................................... 2-3 kgm (14-21 ft/lbs) Cap screw, oil mist recovery pipe (dia. 12 x 1,5 mm)............4 kgm (29 ft/lbs) Self locking nut, con-rod caps securing bolts............... 4.6-4.8 kgm (33-34 ft/lbs) Bolt, rocker pin securing............................................ 0.6-0.8 kgm (4.2-4.5 ft/lbs) Bolt, flywheel to crankshaft...............................................4.2 kgm (30 ft/lbs) Nut, gear to camshaft....................................................... 15 kgm (108 ft/lbs) Screws, intake pipe........................................................... 2 kgm (14 ft/lbs) Cap screw, oil pipe to cyl head................................... 1.5-1.8 kgm (10.5-12 ft/lbs) Nut, front and rear engine securing studs to frame................8 kgm (57 ft/lbs) Nut, layshaft securing..................................................16-18 kgm (115-130 ft/lbs) Oil filler plug, on gearbox and rear drive box........................3 kgm (21 ft/lbs) Oil level and drain plugs, gearbox and rear drive box........ 2.5 kgm (18 ft/lbs) Safety nut, layshaft.........................................................7-8 kgm (50-57 ft/lbs) Nut, bearing to bevel pinion..........................................18-20 kgm (130-145 ft/lbs) Screw, crown wheel to hollow spindle.............................4-4.2 kgm (29-30 ft-lbs) Bolts, cradle to frame securing........................................... 8 kgm (57 ft/lbs) Nut, cradle to frame securing screws...................................8 kgm (57 ft/lbs) Cap nuts, swing arm spindle.............................................. 8 kgm (57 ft/lbs) Nuts, drive box to swing arm...........................................3.5 kgm (25 ft/lbs) Top plugs, front fork.................................................. 12-15 kgm (87-108 ft/lbs) Nut, front and rear wheel spindle................................. 14-15 kgm (100-108 ft/lbs) Bush, steering lock..................................................... 17-18 kgm (122-130 ft/lbs) Brake caliper bolts, 8x1.25mm................................... 2.3-2.5 kgm (16.6-18.1 ft/lbs) Brake caliper fixing bolts, 10x1.5mm...........................3.5-3.8 kgm (25.3-27 ft/lbs) Standard settings Screws and nuts, dia. 6 mm (.23")............................. 0.8-1.2 kgm (4.5-8 ft/lbs) Screws and nuts, dia. 8 mm (.31")................................ 2.5-3 kgm (18-21 ft/lbs) Screws and nuts, dia. 10 mm (.39")...............................4.5-5 kgm (33-37 ft/lbs) Link to comment Share on other sites More sharing options...
txrider Posted March 23, 2005 Author Share Posted March 23, 2005 Thanks, Carl, I'll make a record of that. Link to comment Share on other sites More sharing options...
callison Posted March 23, 2005 Share Posted March 23, 2005 Don't thank me, thank Godfrey DiGeorgio, I snagged that from his EuroMoto web site a few years ago when he had it posted. Link to comment Share on other sites More sharing options...
