al_roethlisberger Posted March 29, 2005 Posted March 29, 2005 If anyone is interested, FYI: http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=35615 $400 doesn't seem too bad. ....of course, you'll need new forks, an "adapter of some sort", or new fork caps to use them. Just an interesting aside, from simply looking at the photo, these seem to basically be built the same as the higher performance "axial mount(normal)" 4 pad Brembos, with the exception of the new radial mounting design. As shown in this thread, these are the 4 pad calipers to which I refer: http://www.v11lemans.com/forums/index.php?showtopic=4726 Does anyone know if these radial calipers are really technically any different than the "axial' 4 pad calipers, again, other than simply being radially mounted? Just curious from a technical standpoint, as I don't plan to retrofit my forks with new end caps. al
jrt Posted March 29, 2005 Posted March 29, 2005 Umm, pardon my ignorance, but what's the difference between axial and radial mount? Jason
al_roethlisberger Posted March 29, 2005 Author Posted March 29, 2005 Radial - The mounting bolts of the caliper align along a radius from the axle(not perfectly, but in general). This is the latest design you see on most "high performance" bikes. Axial(traditional) - The mounting bolts of the caliper are parallel with the axle. This is the standard mounting arrangement you have seen on bikes for decades. What's funny, I don't think anyone bothered to call this design "axial" per se, before we had "radial" versions to differentiate the two Example: Radial Axial(traditional) http://www.hardracing.com/images/01a1.jpg .... I'd post a picture of them installed, but all you have to do is walk out to the garage and look at your front calipers When it is all said and done, the radial calipers are said to stop better and provide improved "feel" in that the radial mounting is more rigid. At least that is what the marketing says Hope that helps. al
Guest Nogbad Posted March 29, 2005 Posted March 29, 2005 Its fashion hype. A properly designed, rigid mount will feel the same regardless of the bolt placement. Maybe the designers feel that by making a "radial" mount they can get the same rigidity with less metal, and hence reduce unsprung weight. IMHO that would be a sensible argument for it if true. All this talk of better feel and better braking is just bullshit.
Guzzirider Posted March 29, 2005 Posted March 29, 2005 Brembo make a kit which enables you to retrofit radial calipers but its bloody expensive. Guy
Guest Nogbad Posted March 29, 2005 Posted March 29, 2005 Brembo make a kit which enables you to retrofit radial calipers but its bloody expensive. Guy 47302[/snapback] And pointless since there is an intermediate bracket that picks up on a non-radial fork bottom, effectively converting the caliper into a less stiff and heavier version of the conventional non-radial type!
al_roethlisberger Posted March 29, 2005 Author Posted March 29, 2005 Brembo make a kit which enables you to retrofit radial calipers but its bloody expensive. Guy 47302[/snapback] And if you have the right make of forks, Ohlins for example... as mentioned in my first post, they do make replacement fork ends for changing out the brake caliper mounts. These too are "bloody expensive" though, not even taking into account the labor required to actually make the change as well. I agree though, that mounting an "adapter" is a waste of time, unless one is simply going for "bling" factor al
kenm Posted March 29, 2005 Posted March 29, 2005 And if you have the right make of forks, Ohlins for example... as mentioned in my first post, they do make replacement fork ends for changing out the brake caliper mounts. 47306[/snapback] Hi Al, Actually, the Ohlins forks that come stock on some Guzzis don't have removable fork ends. That's why Paul sold me his forks. He needed different Ohlins forks to have radial calipers. BTW, upgrading to a radial brake master cylinder makes a big difference in braking feel. I would believe that doing that would be a much better upgrade that to radial calipers and it's a whole lot cheaper. As a bonus, you get an infinitely adjustable handle. Regards, -ken
jrt Posted March 31, 2005 Posted March 31, 2005 thanks for the info. I can see perimeter brakes being referred to as radial, but I don't see how these are. Maybe we should come up with tangential brakes. hmmm, then again maybe that refers to drums...
zebulon Posted April 2, 2005 Posted April 2, 2005 BTW, upgrading to a radial brake master cylinder makes a big difference in braking feel. I would believe that doing that would be a much better upgrade that to radial calipers and it's a whole lot cheaper. As a bonus, you get an infinitely adjustable handle. We can tell it is a non sense to fit radial calipers without a radial master cylinder. On missing Mss Dayto it was a Brembo BILLET 19/20 & this little expensive part have an incredible braking power changes. Even if i only made 35 km with it before disapearing
RacerX Posted April 6, 2005 Posted April 6, 2005 If anyone is interested, FYI:http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=35615$400 doesn't seem too bad. Al/All, I can get them (GuzziTech.com) for $222(USD)/ea brand new (same exact price as the 4-pad axial mounts); http://www.guzzitech.com/Brembo-4padcal-Todd_E.html I ship Worldwide. I also sell the radial m/c. Sold one to KenM above and he's stated they work really well, even as the only mod. My entire upgrade parade summary here; http://www.guzzitech.com/Brembo-Upgrades-Todd_E.html Let me know if I can be of help for anyone, Todd
