Guest freeman Posted April 11, 2005 Share Posted April 11, 2005 I just purchased a 2002 V11 Lemans with aftermarket Mistra pipes. It doesn't have a cross over pipe with the Mistrals. Does anyone know if this is a problem, could it cause problems? Or is there a benefit to adding the cross over pipe now? Link to comment Share on other sites More sharing options...
al_roethlisberger Posted April 11, 2005 Share Posted April 11, 2005 I just purchased a 2002 V11 Lemans with aftermarket Mistra pipes. It doesn't have a cross over pipe with the Mistrals. Does anyone know if this is a problem, could it cause problems? Or is there a benefit to adding the cross over pipe now? 48351[/snapback] Question: Which crossover are you asking about? With 2000-2002 bikes, there was only the main crossover, under the transmission. With 2003+ bikes, they added the front crossover, in front of/above the alternator. If you have a 2002 LeMans, you should only have one crossover, up under the bike's transmission. If you don't have either, it's technically not a problem per se.... although you must have some really custom exhaust system from the headers back, and I would think a totally seperate dual-exhaust system would lose some performance. I suspect you are asking about the 2003+ front crossover though, and if so, the absence of it on your 2002 is normal Hope that helps. al Link to comment Share on other sites More sharing options...
Guest freeman Posted April 11, 2005 Share Posted April 11, 2005 The Mistra canisters were applied from behind the existing crossover (basically just as slip-on's). I've just read a lot on this sight about crossover's. I guess they are only applicable to 2003 or later. Link to comment Share on other sites More sharing options...
al_roethlisberger Posted April 11, 2005 Share Posted April 11, 2005 The Mistra canisters were applied from behind the existing crossover (basically just as slip-on's). I've just read a lot on this sight about crossover's. I guess they are only applicable to 2003 or later. 48412[/snapback] Yeah, MG added the "new"(not really so new, as some old MGs used to have it ) front crossover, marketed as "boosting low/mid torque" in 2003 A lot of folks have had some issues with it as well, as noted in this thread: http://www.v11lemans.com/forums/index.php?...exhaust++gasket .... so it is a mixed bag, but certainly not a big deal either way. If you don't have one, I wouldn't suggest that it is worth pursuing. al Link to comment Share on other sites More sharing options...
