callison Posted April 20, 2005 Share Posted April 20, 2005 Not having a PC, I used a few useful unix commands and extracted this "index" for both cd's and concatenated the information. Maybe this will be useful, and maybe not. A0 Technical Data E Engine ... E10 engine, engine block ...... E10-1 engine, engine block, removal ...... E10-2 engine, engine block, check v750 ...... E10-2A engine, engine block, check v1100 ...... E10-3 engine, engine block, reassembly ... E11 engine, connecting rods ...... E11-1 engine, connecting rods, removal v750 ...... E11-1A engine, connecting rods, removal v1100 ...... E11-2 engine, connecting rods, check ...... E11-3 engine, connecting rods, reassembly v750 ...... E11-3A engine, connecting rods, reassembly v1100 ... E12 engine, crankshaft ...... E12-1 engine, crankshaft, removal and check v750 ...... E12-1A engine, crankshaft, removal v1100 ...... E12-1B engine, crankshaft, check (flanges ) v1100 ...... E12-1C engine, crankshaft, check (crankshaft ) v1100 ...... E12-1D engine, crankshaft, assembly backlashes (connecting rods) v1100 ...... E12-1E engine, crankshaft, reassembly v1100 ...... E12-1F engine, crankshaft, replacing the seal on flywheel-side flange ... E13 engine, oil sump ...... E13-1 engine, oil sump, removal and check v750 ...... E13-1A engine, oil sump, removal and check v1100 ...... E13-2 engine, oil sump, reassembly v750 ...... E13-2A engine, oil sump, reassembly v1100 ...... E13-3 engine, oil pump v750 ...... E13-3A engine, oil sump, oil pump v1100 ...... E13-4 engine, oil pump, oil pump check ...... E13-5 engine, oil pump, oil pressure adjustment valve ...... E13-6 engine, oil pump, oil transmitter ...... E13-7 engine, oil sump, oil filter support v1100 ...E2 engine, head covers ...... E2-1 engine, head covers, removal - check - reassembly v750 ...... E2-1A engine, head covers, removal - check - reassembly v1100 ...E3 engine, timing system ...... E3-1 engine, timing system, alternator disassembly v750 ...... E3-1A engine, timing system, alternator disassembly v1100 ...... E3-2 engine, timing system, rev and stroke sensor ...... E3-3 engine, timing system, timing removal v750 ...... E3-3A engine, timing system, timing removal v1100 ...... E3-4 engine, timing system, timing check v750 ...... E3-4A engine, timing system, timing check v1100 ...... E3-5 engine, timing system, timing reassembly v750 ...... E3-5A engine, timing system, timing reassembly v1100 ...... E3-6 engine, timing system, detailed timing check v750 ...... E3-6A engine, timing system, detailed timing check v1100 ...... E3-6B engine, timing system, detailed timing check v1100 california ...... E3-7 engine, timing system, alternator reassembly v750 ...... E3-7A engine, timing system, alternator reassembly v1100 ...E4 engine, clutch ...... E4-1 engine, clutch, removal v750 ...... E4-1A engine, clutch, removal v1100 ...... E4-2 engine, clutch, check v750 ...... E4-2A engine, clutch, check v1100 ...... E4-3 engine, clutch, reassembly v750 ...... E4-3A engine, clutch, reassembly v1100 ...E5 engine, flywheel ...... E5-1 engine, flywheel, removal v750 ...... E5-1A engine, flywheel, removal v1100 ...... E5-2 engine, flywheel, check ...... E5-3 engine, flywheel, reassembly v750 ...... E5-3A engine, flywheel, reassembly v1100 ...E6 engine, engine heads ...... E6-1 engine, engine heads, heads disassembly v750 ...... E6-1A engine, engine heads, heads disassembly v1100 ...... E6-1B engine, engine heads, heads disassembly v1100 california ...... E6-2 engine, engine heads, head valves disassembly v750 ...... E6-2A engine, engine heads, head valves disassembly v1100 ...... E6-3 engine, engine heads, valve guides and valve seats v750 ...... E6-3A engine, engine heads, valve guides and valve seats v1100 ...... E6-3B engine, engine heads, head valves reassembly v1100 ...... E6-5 engine, engine heads, heads reassembly v750 ...... E6-5A engine, engine heads, heads reassembly v1100 california ...... E6-6 engine, engine heads, valve clearance ...E7 engine, cylinders ...... E7-1 engine, cylinders, removal v750 ...... E7-1A engine, cylinders, removal v1100 ...... E7-2 engine, cylinders, check ...... E7-3 engine, cylinders, reassembly v750 ...... E7-3A engine, cylinders, reassembly v1100 ...E8 engine, pistons ...... E8-1 engine, pistons, removal v750 ...... E8-1A engine, pistons, removal v1100 ...... E8-2 engine, pistons, check v750 ...... E8-2A engine, pistons, check v1100 ...... E8-3 engine, pistons, reassembly v750 ...... E8-3A engine, pistons, reassembly v1100 ...E9 engine, compression ring ...... E9-1 engine, compression ring, removal - check - reassembly v750 ...... E9-1A engine, compression ring, removal - check - reassembly v1100 A0 technical data E Engine ...E10 engine, engine block ...... E10-1 engine, engine block, removal ...... E10-2 engine, engine block, check v750 ...... E10-2A engine, engine block, check v1100 ...... E10-3 engine, engine block, reassembly ...E11 engine, connecting rods ...... E11-1 engine, connecting rods, removal v750 ...... E11-1A engine, connecting rods, removal v1100 ...... E11-2 engine, connecting rods, check ...... E11-3 engine, connecting rods, reassembly v750 ...... E11-3A engine, connecting rods, reassembly v1100 ...E12 engine, crankshaft ...... E12-1 engine, crankshaft, removal and check v750 ...... E12-1A engine, crankshaft, removal v1100 ...... E12-1B engine, crankshaft, check (flanges ) v1100 ...... E12-1C engine, crankshaft, check (crankshaft ) v1100 ...... E12-1D engine, crankshaft, assembly backlashes (connecting rods) v1100 ...... E12-1E engine, crankshaft, reassembly v1100 ...... E12-1F engine, crankshaft, replacing the seal on flywheel-side flange ...E13 engine, oil sump ...... E13-1 engine, oil sump, removal and check v750 ...... E13-1A engine, oil sump, removal and check v1100 ...... E13-2 engine, oil sump, reassembly v750 ...... E13-2A engine, oil sump, reassembly v1100 ...... E13-3 engine, oil pump v750 ...... E13-3A engine, oil sump, oil pump v1100 ...... E13-4 engine, oil pump, oil pump check ...... E13-5 engine, oil pump, oil pressure adjustment valve ...... E13-6 engine, oil pump, oil transmitter ...... E13-7 engine, oil sump, oil filter support v1100 ...E2 engine, head covers ...... E2-1 engine, head covers, removal - check - reassembly v750 ...... E2-1A engine, head covers, removal - check - reassembly v1100 ...E3 engine, timing system ...... E3-1 engine, timing system, alternator disassembly v750 ...... E3-1A engine, timing system, alternator disassembly v1100 ...... E3-2 engine, timing system, rev and stroke sensor ...... E3-3 engine, timing system, timing removal v750 ...... E3-3A engine, timing system, timing removal v1100 ...... E3-4 engine, timing system, timing check v750 ...... E3-4A engine, timing system, timing check v1100 ...... E3-5 engine, timing system, timing reassembly v750 ...... E3-5A engine, timing system, timing reassembly v1100 ...... E3-6 engine, timing system, detailed timing check v750 ...... E3-6A engine, timing system, detailed timing check v1100 ...... E3-6B engine, timing system, detailed timing check v1100 california ...... E3-7 engine, timing system, alternator reassembly v750 ...... E3-7A engine, timing system, alternator reassembly v1100 ...E4 engine, clutch ...... E4-1 engine, clutch, removal v750 ...... E4-1A engine, clutch, removal v1100 ...... E4-2 engine, clutch, check v750 ...... E4-2A engine, clutch, check v1100 ...... E4-3 engine, clutch, reassembly v750 ...... E4-3A engine, clutch, reassembly v1100 ...E5 engine, flywheel ...... E5-1 engine, flywheel, removal v750 ...... E5-1A engine, flywheel, removal v1100 ...... E5-2 engine, flywheel, check ...... E5-3 engine, flywheel, reassembly v750 ...... E5-3A engine, flywheel, reassembly v1100 ...E6 engine, engine heads ...... E6-1 engine, engine heads, heads disassembly v750 ...... E6-1A engine, engine heads, heads disassembly v1100 ...... E6-1B engine, engine heads, heads disassembly v1100 california ...... E6-2 engine, engine heads, head valves disassembly v750 ...... E6-2A engine, engine heads, head valves disassembly v1100 ...... E6-3 engine, engine heads, valve guides and valve seats v750 ...... E6-3A engine, engine heads, valve guides and valve seats v1100 ...... E6-3B engine, engine heads, head valves reassembly v1100 ...... E6-5 engine, engine heads, heads reassembly v750 ...... E6-5A engine, engine heads, heads reassembly v1100 california ...... E6-6 engine, engine heads, valve clearance ...E7 engine, cylinders ...... E7-1 engine, cylinders, removal v750 ...... E7-1A engine, cylinders, removal v1100 ...... E7-2 engine, cylinders, check ...... E7-3 engine, cylinders, reassembly v750 ...... E7-3A engine, cylinders, reassembly v1100 ...E8 engine, pistons ...... E8-1 engine, pistons, removal v750 ...... E8-1A engine, pistons, removal v1100 ...... E8-2 engine, pistons, check v750 ...... E8-2A engine, pistons, check v1100 ...... E8-3 engine, pistons, reassembly v750 ...... E8-3A engine, pistons, reassembly v1100 ...E9 engine, compression ring ...... E9-1 engine, compression ring, removal - check - reassembly v750 ...... E9-1A engine, compression ring, removal - check - reassembly v1100 A0 technical data E Engine ...E10 engine, engine block ...... E10-1 engine, engine block, removal ...... E10-2 engine, engine block, check v750 ...... E10-2A engine, engine block, check v1100 ...... E10-3 engine, engine block, reassembly ...E11 engine, connecting rods ...... E11-1 engine, connecting rods, removal v750 ...... E11-1A engine, connecting rods, removal v1100 ...... E11-2 engine, connecting rods, check ...... E11-3 engine, connecting rods, reassembly v750 ...... E11-3A engine, connecting rods, reassembly v1100 ...E12 engine, crankshaft ...... E12-1 engine, crankshaft, removal and check v750 ...... E12-1A engine, crankshaft, removal v1100 ...... E12-1B engine, crankshaft, check (flanges ) v1100 ...... E12-1C engine, crankshaft, check (crankshaft ) v1100 ...... E12-1D engine, crankshaft, assembly backlashes (connecting rods) v1100 ...... E12-1E engine, crankshaft, reassembly v1100 ...... E12-1F engine, crankshaft, replacing the seal on flywheel-side flange ...E13 engine, oil sump ...... E13-1 engine, oil sump, removal and check v750 ...... E13-1A engine, oil sump, removal and check v1100 ...... E13-2 engine, oil sump, reassembly v750 ...... E13-2A engine, oil sump, reassembly v1100 ...... E13-3 engine, oil pump v750 ...... E13-3A engine, oil sump, oil pump v1100 ...... E13-4 engine, oil pump, oil pump check ...... E13-5 engine, oil pump, oil pressure adjustment valve ...... E13-6 engine, oil pump, oil transmitter ...... E13-7 engine, oil sump, oil filter support v1100 ...E2 engine, head covers ...... E2-1 engine, head covers, removal - check - reassembly v750 ...... E2-1A engine, head covers, removal - check - reassembly v1100 ...E3 engine, timing system ...... E3-1 engine, timing system, alternator disassembly v750 ...... E3-1A engine, timing system, alternator disassembly v1100 ...... E3-2 engine, timing system, rev and stroke sensor ...... E3-3 engine, timing system, timing removal v750 ...... E3-3A engine, timing system, timing removal v1100 ...... E3-4 engine, timing system, timing check v750 ...... E3-4A engine, timing system, timing check v1100 ...... E3-5 engine, timing system, timing reassembly v750 ...... E3-5A engine, timing system, timing reassembly v1100 ...... E3-6 engine, timing system, detailed timing check v750 ...... E3-6A engine, timing system, detailed timing check v1100 ...... E3-6B engine, timing system, detailed timing check v1100 california ...... E3-7 engine, timing system, alternator reassembly v750 ...... E3-7A engine, timing system, alternator reassembly v1100 ...E4 engine, clutch ...... E4-1 engine, clutch, removal v750 ...... E4-1A engine, clutch, removal v1100 ...... E4-2 engine, clutch, check v750 ...... E4-2A engine, clutch, check v1100 ...... E4-3 engine, clutch, reassembly v750 ...... E4-3A engine, clutch, reassembly v1100 ...E5 engine, flywheel ...... E5-1 engine, flywheel, removal v750 ...... E5-1A engine, flywheel, removal v1100 ...... E5-2 engine, flywheel, check ...... E5-3 engine, flywheel, reassembly v750 ...... E5-3A engine, flywheel, reassembly v1100 ...E6 engine, engine heads ...... E6-1 engine, engine heads, heads disassembly v750 ...... E6-1A engine, engine heads, heads disassembly v1100 ...... E6-1B engine, engine heads, heads disassembly v1100 california ...... E6-2 engine, engine heads, head valves disassembly v750 ...... E6-2A engine, engine heads, head valves disassembly v1100 ...... E6-3 engine, engine heads, valve guides and valve seats v750 ...... E6-3A engine, engine heads, valve guides and valve seats v1100 ...... E6-3B engine, engine heads, head valves reassembly v1100 ...... E6-5 engine, engine heads, heads reassembly v750 ...... E6-5A engine, engine heads, heads reassembly v1100 california ...... E6-6 engine, engine heads, valve clearance ...E7 engine, cylinders ...... E7-1 engine, cylinders, removal v750 ...... E7-1A engine, cylinders, removal v1100 ...... E7-2 engine, cylinders, check ...... E7-3 engine, cylinders, reassembly v750 ...... E7-3A engine, cylinders, reassembly v1100 ...E8 engine, pistons ...... E8-1 engine, pistons, removal v750 ...... E8-1A engine, pistons, removal v1100 ...... E8-2 engine, pistons, check v750 ...... E8-2A engine, pistons, check v1100 ...... E8-3 engine, pistons, reassembly v750 ...... E8-3A engine, pistons, reassembly v1100 ...E9 engine, compression ring ...... E9-1 engine, compression ring, removal - check - reassembly v750 ...... E9-1A engine, compression ring, removal - check - reassembly v1100 A0 technical data E Engine ...... E10 engine, engine block ...... E10-1 engine, engine block, removal ...... E10-2 engine, engine block, check v750 ...... E10-2A engine, engine block, check v1100 ...... E10-3 engine, engine block, reassembly ...E11 engine, connecting rods ...... E11-1 engine, connecting rods, removal v750 ...... E11-1A engine, connecting rods, removal v1100 ...... E11-2 engine, connecting rods, check ...... E11-3 engine, connecting rods, reassembly v750 ...... E11-3A engine, connecting rods, reassembly v1100 ...E12 engine, crankshaft ...... E12-1 engine, crankshaft, removal and check v750 ...... E12-1A engine, crankshaft, removal v1100 ...... E12-1B engine, crankshaft, check (flanges ) v1100 ...... E12-1C engine, crankshaft, check (crankshaft ) v1100 ...... E12-1D engine, crankshaft, assembly backlashes (connecting rods) v1100 ...... E12-1E engine, crankshaft, reassembly v1100 ...... E12-1F engine, crankshaft, replacing the seal on flywheel-side flange ...E13 engine, oil sump ...... E13-1 engine, oil sump, removal and check v750 ...... E13-1A engine, oil sump, removal and check v1100 ...... E13-2 engine, oil sump, reassembly v750 ...... E13-2A engine, oil sump, reassembly v1100 ...... E13-3 engine, oil pump v750 ...... E13-3A engine, oil sump, oil pump v1100 ...... E13-4 engine, oil pump, oil pump check ...... E13-5 engine, oil pump, oil pressure adjustment valve ...... E13-6 engine, oil pump, oil transmitter ...... E13-7 engine, oil sump, oil filter support v1100 ...E2 engine, head covers ...... E2-1 engine, head covers, removal - check - reassembly v750 ...... E2-1A engine, head covers, removal - check - reassembly v1100 ...E3 engine, timing system ...... E3-1 engine, timing system, alternator disassembly v750 ...... E3-1A engine, timing system, alternator disassembly v1100 ...... E3-2 engine, timing system, rev and stroke sensor ...... E3-3 engine, timing system, timing removal v750 ...... E3-3A engine, timing system, timing removal v1100 ...... E3-4 engine, timing system, timing check v750 ...... E3-4A engine, timing system, timing check v1100 ...... E3-5 engine, timing system, timing reassembly v750 ...... E3-5A engine, timing system, timing reassembly v1100 ...... E3-6 engine, timing system, detailed timing check v750 ...... E3-6A engine, timing system, detailed timing check v1100 ...... E3-6B engine, timing system, detailed timing check v1100 california ...... E3-7 engine, timing system, alternator reassembly v750 ...... E3-7A engine, timing system, alternator reassembly v1100 ...E4 engine, clutch ...... E4-1 engine, clutch, removal v750 ...... E4-1A engine, clutch, removal v1100 ...... E4-2 engine, clutch, check v750 ...... E4-2A engine, clutch, check v1100 ...... E4-3 engine, clutch, reassembly v750 ...... E4-3A engine, clutch, reassembly v1100 ...E5 engine, flywheel ...... E5-1 engine, flywheel, removal v750 ...... E5-1A engine, flywheel, removal v1100 ...... E5-2 engine, flywheel, check ...... E5-3 engine, flywheel, reassembly v750 ...... E5-3A engine, flywheel, reassembly v1100 ...E6 engine, engine heads ...... E6-1 engine, engine heads, heads disassembly v750 ...... E6-1A engine, engine heads, heads disassembly v1100 ...... E6-1B engine, engine heads, heads disassembly v1100 california ...... E6-2 engine, engine heads, head valves disassembly v750 ...... E6-2A engine, engine heads, head valves disassembly v1100 ...... E6-3 engine, engine heads, valve guides and valve seats v750 ...... E6-3A engine, engine heads, valve guides and valve seats v1100 ...... E6-3B engine, engine heads, head valves reassembly v1100 ...... E6-5 engine, engine heads, heads reassembly v750 ...... E6-5A engine, engine heads, heads reassembly v1100 california ...... E6-6 engine, engine heads, valve clearance ...E7 engine, cylinders ...... E7-1 engine, cylinders, removal v750 ...... E7-1A engine, cylinders, removal v1100 ...... E7-2 engine, cylinders, check ...... E7-3 engine, cylinders, reassembly v750 ...... E7-3A engine, cylinders, reassembly v1100 ...E8 engine, pistons ...... E8-1 engine, pistons, removal v750 ...... E8-1A engine, pistons, removal v1100 ...... E8-2 engine, pistons, check v750 ...... E8-2A engine, pistons, check v1100 ...... E8-3 engine, pistons, reassembly v750 ...... E8-3A engine, pistons, reassembly v1100 ...E9 engine, compression ring ...... E9-1 engine, compression ring, removal - check - reassembly v750 ...... E9-1A engine, compression ring, removal - check - reassembly v1100 F gearbox ...F1 gearbox, gearbox housing ...... F1-1 gearbox, gearbox housing, removal ...... F1-2 gearbox, gearbox housing, reassembly ...F2 gearbox, clutch housing ...... F2-1 gearbox, clutch housing, removal ...... F2-2 gearbox, clutch housing, reassembly ...F3 gearbox, gears v750 ...F4 gearbox, gears v1100 G transmission ...G2 transmission, pinion housing ...... G2-1 transmission, pinion housing, removal ...... G2-2 transmission, pinion housing, check ...... G2-3 transmission, pinion housing, reassembly ...G3 transmission, transmission case ...... G3-1 transmission, transmission case, removal ...... G3-2 transmission, transmission case, check ...... G3-3 transmission, transmission case, pinion - gear meshing (bevel gear set) ...... G3-4 transmission, transmission case, reassembly D fuel system ...D3 fuel system, cylinder synchronisation 750 breva ...... D3-A fuel system, cylinder synchronisation v1100 ...... D3-B fuel system, cylinder synchronisation california F gearbox ...F1 gearbox, gearbox housing ...... F1-1 gearbox, gearbox housing, removal ...... F1-2 gearbox, gearbox housing, reassembly ...F2 gearbox, clutch housing ...... F2-1 gearbox, clutch housing, removal ...... F2-2 gearbox, clutch housing, reassembly ...F3 gearbox, gears v750 ...F4 gearbox, gears v1100 G transmission ...G2 transmission, pinion housing ...... G2-1 transmission, pinion housing, removal ...... G2-2 transmission, pinion housing, check ...... G2-3 transmission, pinion housing, reassembly ...G3 transmission, transmission case ...... G3-1 transmission, transmission case, removal ...... G3-2 transmission, transmission case, check ...... G3-3 transmission, transmission case, pinion - gear meshing (bevel gear set) ...... G3-4 transmission, transmission case, reassembly D fuel system ...D3 fuel system, cylinder synchronisation 750 breva ...... D3-A fuel system, cylinder synchronisation v1100 ...... D3-B fuel system, cylinder synchronisation california F gearbox ...F1 gearbox, gearbox housing ...... F1-1 gearbox, gearbox housing, removal ...... F1-2 gearbox, gearbox housing, reassembly ...F2 gearbox, clutch housing ...... F2-1 gearbox, clutch housing, removal ...... F2-2 gearbox, clutch housing, reassembly ...F3 gearbox, gears v750 ...F4 gearbox, gears v1100 G transmission ...G2 transmission, pinion housing ...... G2-1 transmission, pinion housing, removal ...... G2-2 transmission, pinion housing, check ...... G2-3 transmission, pinion housing, reassembly ...G3 transmission, transmission case ...... G3-1 transmission, transmission case, removal ...... G3-2 transmission, transmission case, check ...... G3-3 transmission, transmission case, pinion - gear meshing (bevel gear set) ...... G3-4 transmission, transmission case, reassembly D fuel system ...D3 fuel system, cylinder synchronisation 750 breva ...... D3-A fuel system, cylinder synchronisation v1100 ...... D3-B fuel system, cylinder synchronisation california F gearbox ...F1 gearbox, gearbox housing ...... F1-1 gearbox, gearbox housing, removal ...... F1-2 gearbox, gearbox housing, reassembly ...F2 gearbox, clutch housing ...... F2-1 gearbox, clutch housing, removal ...... F2-2 gearbox, clutch housing, reassembly ...F3 gearbox, gears v750 ...F4 gearbox, gears v1100 G transmission ...G2 transmission, pinion housing ...... G2-1 transmission, pinion housing, removal ...... G2-2 transmission, pinion housing, check ...... G2-3 transmission, pinion housing, reassembly ...G3 transmission, transmission case ...... G3-1 transmission, transmission case, removal ...... G3-2 transmission, transmission case, check ...... G3-3 transmission, transmission case, pinion - gear meshing (bevel gear set) ...... G3-4 transmission, transmission case, reassembly D fuel system ...D3 fuel system, cylinder synchronisation 750 breva ...... D3-A fuel system, cylinder synchronisation v1100 ...... D3-B fuel system, cylinder synchronisation california F gearbox ...F1 gearbox, gearbox housing ...... F1_1 gearbox, gearbox housing, removal ...... F1_2 gearbox, gearbox housing, reassembly ...F2 gearbox, clutch housing ...... F2_1 gearbox, clutch housing, removal ...... F2_2 gearbox, clutch housing, reassembly ...F3 gearbox, gears v750 ...F4 gearbox, gears v1100 G transmission ...G2 transmission, pinion housing ...... G2_1 transmission, pinion housing, removal ...... G2_2 transmission, pinion housing, check ...... G2_3 transmission, pinion housing, reassembly ...G3 transmission, transmission case ...... G3_1 transmission, transmission case, removal ...... G3_2 transmission, transmission case, check ...... G3_3 transmission, transmission case, pinion - gear meshing (bevel gear set) ...... G3_4 transmission, transmission case, reassembly D fuel system ...D3 fuel system, cylinder synchronisation 750 breva ...... D3_A fuel system, cylinder synchronisation v1100 ...... D3_B fuel system, cylinder synchronisation california Link to comment Share on other sites More sharing options...
Guest PHXv11 Posted April 20, 2005 Share Posted April 20, 2005 I have made 2 over night attempts to download these CD's on my slow dial up connection. Can any one in the US please burn me a copy? I will play for shipping, cost for blank CD and your time. Guzzi Newbe Phoenix Arizona Link to comment Share on other sites More sharing options...
Alex-Corsa Posted April 20, 2005 Share Posted April 20, 2005 I have downloaded both if anyone wants a copy sending snail mail I can burn a copy off. 49204[/snapback] Thanks,that would be great. PM me your email and I'll send you my snail address,Willing to pay postage and the CDs Cheers Link to comment Share on other sites More sharing options...
jrt Posted April 20, 2005 Share Posted April 20, 2005 I have made 2 over night attempts to download these CD's on my slow dial up connection. Can any one in the US please burn me a copy? I will play for shipping, cost for blank CD and your time. Guzzi Newbe Phoenix Arizona 49226[/snapback] PM me your address. I got both working now (I think). J Link to comment Share on other sites More sharing options...
Martin Barrett Posted April 21, 2005 Share Posted April 21, 2005 Thanks Paul Link to comment Share on other sites More sharing options...
tikkanen Posted April 21, 2005 Share Posted April 21, 2005 Thumbs up, Paul Thanks a bunch! Søren Link to comment Share on other sites More sharing options...
Guest philbo Posted April 21, 2005 Share Posted April 21, 2005 Thumbs up, Paul Thanks a bunch! Søren 49267[/snapback] Worked like a charm - Cheers Link to comment Share on other sites More sharing options...
Pascal Posted April 21, 2005 Share Posted April 21, 2005 Thank's a lot for these wonderful CD'S Link to comment Share on other sites More sharing options...
belfastguzzi Posted April 21, 2005 Share Posted April 21, 2005 Not having a PC, I used a few useful unix commands and extracted this "index" for both cd's and concatenated the information. Maybe this will be useful, and maybe not. 49216[/snapback] Brilliant Carl. As it's set-up for for the Wintel world, I wanted to ask if anyone could do an index, but I didn't dare. I also found that I have to extract/disable audio tracks as some videos play in 5 languages at once. Link to comment Share on other sites More sharing options...
callison Posted April 21, 2005 Share Posted April 21, 2005 Brilliant Carl. As it's set-up for for the Wintel world, I wanted to ask if anyone could do an index, but I didn't dare. I also found that I have to extract/disable audio tracks as some videos play in 5 languages at once. 49299[/snapback] How do you extract the audio tracks and what application/operating system? Link to comment Share on other sites More sharing options...
belfastguzzi Posted April 21, 2005 Share Posted April 21, 2005 How do you extract the audio tracks and what application/operating system? 49300[/snapback] In QuickTime menu > Edit then there is a selection of Enable Tracks, Extract Tracks, Delete Tracks. This is QT 6.5.2 but as far as I remember over recent years all versions have had this feature HOWEVER it may just be with QT Pro. If you are using standard QT player and haven't enabled Pro for the additional editing features then the tracks may not show. For example, the first video on cd2 is 'e2-1.mov'. It has 1 video track and 5 audio tracks, which can all be switched off/on or deleted. Link to comment Share on other sites More sharing options...
jrt Posted April 21, 2005 Share Posted April 21, 2005 QT lite...or regular or whatever doesn't have that feature. I haven't figured an easy way to do it yet, but you can extract them painfully one at a time with ffmpegx. English is track 2. J Link to comment Share on other sites More sharing options...
Paul Minnaert Posted April 21, 2005 Author Share Posted April 21, 2005 Carl, maybe this will do it? http://xinehq.de/ Link to comment Share on other sites More sharing options...
callison Posted April 21, 2005 Share Posted April 21, 2005 Carl, maybe this will do it? http://xinehq.de/ 49317[/snapback] Unfortunately, no. OSX is unix. Sort of. I have YDL too, but that isn't covered with a binary and I don't feel any strong desire to boot up YDL and build the application. Something I'm not particularly good at. I started to purchase QT Pro from Apple since that will do the job, but my router crashed in the middle, so I'm stuck waiting to see if Apple will send me the download ID or whether I'll have to pay $30 twice for one copy. Sort of sucks. Link to comment Share on other sites More sharing options...
belfastguzzi Posted April 21, 2005 Share Posted April 21, 2005 Unfortunately, no. OSX is unix. Sort of. I have YDL too, but that isn't covered with a binary and I don't feel any strong desire to boot up YDL and build the application. Something I'm not particularly good at. I started to purchase QT Pro from Apple since that will do the job, but my router crashed in the middle, so I'm stuck waiting to see if Apple will send me the download ID or whether I'll have to pay $30 twice for one copy. Sort of sucks. 49321[/snapback] Maybe I can 'help you out' if you can't pick-up where you left off with that process. Hopefully, once you initiated the order the Apple Store will have your order record and it can be sorted. But if not...p.m. QT Pro does lots of nice stuff and is worth getting. Link to comment Share on other sites More sharing options...
