For non-PC. I have cleaned up the index, from Carl. It's reduced by a third. It was formatted in Word to differentiate v11 from Breva, but this is lost here.
A0 Technical Data
D fuel system
D3 fuel system, cylinder synchronisation 750 breva
D3-A fuel system, cylinder synchronisation v1100
D3-B fuel system, cylinder synchronisation
E Engine
E2 head covers
E2-1 engine, head covers, removal - check - reassembly v750
E2-1A engine, head covers, removal - check - reassembly v1100
E3 timing system
E3-1 engine, timing system, alternator disassembly v750
E3-1A engine, timing system, alternator disassembly v1100
E3-2 engine, timing system, rev and stroke sensor
E3-3 engine, timing system, timing removal v750
E3-3A engine, timing system, timing removal v1100
E3-4 engine, timing system, timing check v750
E3-4A engine, timing system, timing check v1100
E3-5 engine, timing system, timing reassembly v750
E3-5A engine, timing system, timing reassembly v1100
E3-6 engine, timing system, detailed timing check v750
E3-6A engine, timing system, detailed timing check v1100
E3-6B engine, timing system, detailed timing check v1100 california
E3-7 engine, timing system, alternator reassembly v750
E3-7A engine, timing system, alternator reassembly v1100
E4 clutch
E4-1 engine, clutch, removal v750
E4-1A engine, clutch, removal v1100
E4-2 engine, clutch, check v750
E4-2A engine, clutch, check v1100
E4-3 engine, clutch, reassembly v750
E4-3A engine, clutch, reassembly v1100
E5 flywheel
E5-1 engine, flywheel, removal v750
E5-1A engine, flywheel, removal v1100
E5-2 engine, flywheel, check
E5-3 engine, flywheel, reassembly v750
E5-3A engine, flywheel, reassembly v1100
E6 engine heads
E6-1 engine, engine heads, heads disassembly v750
E6-1A engine, engine heads, heads disassembly v1100
E6-1B engine, engine heads, heads disassembly v1100 california
E6-2 engine, engine heads, head valves disassembly v750
E6-2A engine, engine heads, head valves disassembly v1100
E6-3 engine, engine heads, valve guides and valve seats v750
E6-3A engine, engine heads, valve guides and valve seats v1100
E6-3B engine, engine heads, head valves reassembly v1100
E6-5 engine, engine heads, heads reassembly v750
E6-5A engine, engine heads, heads reassembly v1100 california
E6-6 engine, engine heads, valve clearance
E7 cylinders
E7-1 engine, cylinders, removal v750
E7-1A engine, cylinders, removal v1100
E7-2 engine, cylinders, check
E7-3 engine, cylinders, reassembly v750
E7-3A engine, cylinders, reassembly v1100
E8 pistons
E8-1 engine, pistons, removal v750
E8-1A engine, pistons, removal v1100
E8-2 engine, pistons, check v750
E8-2A engine, pistons, check v1100
E8-3 engine, pistons, reassembly v750
E8-3A engine, pistons, reassembly v1100
E9 compression ring
E9-1 engine, compression ring, removal - check - reassembly v750
E9-1A engine, compression ring, removal - check - reassembly v1100
E10 engine block
E10-1 engine, engine block, removal
E10-2 engine, engine block, check v750
E10-2A engine, engine block, check v1100
E10-3 engine, engine block, reassembly
E11 connecting rods
E11-1 engine, connecting rods, removal v750
E11-1A engine, connecting rods, removal v1100
E11-2 engine, connecting rods, check
E11-3 engine, connecting rods, reassembly v750
E11-3A engine, connecting rods, reassembly v1100
E12 crankshaft
E12-1 engine, crankshaft, removal and check v750
E12-1A engine, crankshaft, removal v1100
E12-1B engine, crankshaft, check (flanges ) v1100
E12-1C engine, crankshaft, check (crankshaft ) v1100
E12-1D engine, crankshaft, assembly backlashes (connecting rods) v1100
E12-1E engine, crankshaft, reassembly v1100
E12-1F engine, crankshaft, replacing the seal on flywheel-side flange
E13 oil sump
E13-1 engine, oil sump, removal and check v750
E13-1A engine, oil sump, removal and check v1100
E13-2 engine, oil sump, reassembly v750
E13-2A engine, oil sump, reassembly v1100
E13-3 engine, oil pump v750
E13-3A engine, oil sump, oil pump v1100
E13-4 engine, oil pump, oil pump check
E13-5 engine, oil pump, oil pressure adjustment valve
E13-6 engine, oil pump, oil transmitter
E13-7 engine, oil sump, oil filter support v1100
F gearbox
F1 gearbox, gearbox housing
F1-1 gearbox, gearbox housing, removal
F1-2 gearbox, gearbox housing, reassembly
F2 gearbox, clutch housing
F2-1 gearbox, clutch housing, removal
F2-2 gearbox, clutch housing, reassembly
F3 gearbox, gears v750
F4 gearbox, gears v1100
G transmission
G2 transmission, pinion housing
G2-1 transmission, pinion housing, removal
G2-2 transmission, pinion housing, check
G2-3 transmission, pinion housing, reassembly
G3 transmission, transmission case
G3-1 transmission, transmission case, removal
G3-2 transmission, transmission case, check
G3-3 transmission, transmission case, pinion - gear meshing (bevel gear set)
G3-4 transmission, transmission case, reassembly
california
  • Replies 49
  • Created
  • Last Reply
Top Posters In This Topic
Maybe I can 'help you out'  ;) if you can't pick-up where you left off with that process. Hopefully, once you initiated the order the Apple Store will have your order record and it can be sorted. But if not...p.m. :whistle:
QT Pro does lots of nice stuff and is worth getting.
49334[/snapback]
Well, I now have QT Pro installed and I've gone through all of the videos manually and set them to English language only. Neat videos. Now if I only had all of those special tools...
Guest Jeff in Ohio
If I send someone in the USA blanks, can tehy burn me off a set? My work machine can plug along at a high rate of speed, but the download always bombs around 40% complete or so. Don;t know why, I have like 16Gb disk space available. PM me if you can help...........
49384[/snapback]
My Mac was doing likewise. I guessed that it might be going to sleep or something, but no settings in the control panel seemed to make any difference. I finally wrote a shell script to monitor the directory every 30 seconds and since that was an active process, the computer quit going to sleep or whatever it was doing and I finally got the downloads. Not entirely complete for one of them, but I did get all of the .pdf files and the videos. The PC stuff is of no use to me, so I doubt that I'm missing anything important.
Since your problem might be a sleep or application inactivity type of thing, you might want to check the display, screensaver, energy savers or whatever on your system to ensure that they're all off and then give it another shot.
Each took two hours on my down load, being inherantly lazy , I just wiggled the mouse every 15 mins or so
Guest Jeff in Ohio
nope, my PC does not go to sleep since I am working on it during download. Even if i walk away for awile, it still chokes on the download. I can rip off a download here at work at 400+kb/sec. After about 10 miuntes, it usually chokes anywhere from 25% to 50% done.....
Guest slowpoke
I seemed to have gotten most of it and from what I have seen it seems to be what every Guzzi owner needs an "how to" video. Now if I can just eliminate the other languages and reduce it to English I'll be fine. Thanks, Paul.
Why don't you use a download manager and finish it in 2-3 takes?
49397[/snapback]
Update to QuickTime Pro for $30 and then you can turn on or off individual tracks. There's a lot of movies though, so it took me a while to go through them all. In a way, it's sort of fun to listen to them all at once. Sounds like some parties I've been to after a few too many drinks...
Guest burke
I have tried 3 times now and after 5 hours each I get the "does not appear to be a valid archive" error.
Can someone copy their CD and send it to me? I would be glad to pay for the blank CD and Shipping.
Thanks
Burke
Not having a PC, I used a few useful unix commands and extracted this "index" for both cd's and concatenated the information. Maybe this will be useful, and maybe not.
A0 Technical Data
E Engine
... E10 engine,  engine block
...... E10-1  engine,  engine block, removal
...... E10-2  engine,  engine block, check v750
...... E10-2A  engine,  engine block, check v1100
...... E10-3  engine,  engine block, reassembly
... E11    engine, connecting rods
...... E11-1  engine, connecting rods, removal v750
...... E11-1A  engine, connecting rods, removal v1100
...... E11-2  engine, connecting rods, check
...... E11-3  engine, connecting rods, reassembly v750
...... E11-3A  engine, connecting rods, reassembly v1100
... E12    engine, crankshaft
...... E12-1  engine, crankshaft, removal and check v750
...... E12-1A  engine, crankshaft, removal v1100
...... E12-1B  engine, crankshaft, check (flanges ) v1100
...... E12-1C  engine, crankshaft, check (crankshaft ) v1100
...... E12-1D  engine, crankshaft, assembly backlashes (connecting rods) v1100
...... E12-1E  engine, crankshaft, reassembly v1100
...... E12-1F  engine, crankshaft, replacing the seal on flywheel-side flange
... E13 engine, oil sump
...... E13-1  engine, oil sump, removal and check v750
...... E13-1A  engine, oil sump, removal and check v1100
...... E13-2  engine, oil sump, reassembly v750
...... E13-2A  engine, oil sump, reassembly v1100
...... E13-3  engine, oil pump v750
...... E13-3A  engine, oil sump, oil pump v1100
...... E13-4  engine, oil pump, oil pump check
...... E13-5  engine, oil pump, oil pressure adjustment valve
...... E13-6  engine, oil pump, oil transmitter
...... E13-7  engine, oil sump, oil filter support v1100
...E2 engine, head covers
...... E2-1    engine, head covers, removal - check - reassembly v750
...... E2-1A  engine, head covers, removal - check - reassembly v1100
...E3 engine, timing system
...... E3-1    engine, timing system, alternator disassembly v750
...... E3-1A  engine, timing system, alternator disassembly v1100
...... E3-2    engine, timing system, rev and stroke sensor
...... E3-3    engine, timing system, timing removal v750
...... E3-3A  engine, timing system, timing removal v1100
...... E3-4    engine, timing system, timing check v750
...... E3-4A  engine, timing system, timing check v1100
...... E3-5    engine, timing system, timing reassembly v750
...... E3-5A  engine, timing system, timing reassembly v1100
...... E3-6    engine, timing system, detailed timing check v750
...... E3-6A  engine, timing system, detailed timing check v1100
...... E3-6B  engine, timing system, detailed timing check v1100 california
...... E3-7    engine, timing system, alternator reassembly v750
...... E3-7A  engine, timing system, alternator reassembly v1100
...E4 engine, clutch
...... E4-1    engine, clutch, removal v750
...... E4-1A  engine, clutch, removal v1100
...... E4-2    engine, clutch, check v750
...... E4-2A  engine, clutch, check v1100
...... E4-3    engine, clutch, reassembly v750
...... E4-3A  engine, clutch, reassembly v1100
...E5 engine, flywheel
...... E5-1    engine, flywheel, removal v750
...... E5-1A  engine, flywheel, removal v1100
...... E5-2    engine, flywheel, check
...... E5-3    engine, flywheel, reassembly v750
...... E5-3A  engine, flywheel, reassembly v1100
...E6 engine, engine heads
...... E6-1    engine, engine heads, heads disassembly v750
...... E6-1A  engine, engine heads, heads disassembly v1100
...... E6-1B  engine, engine heads, heads disassembly v1100 california
...... E6-2    engine, engine heads, head valves disassembly v750
...... E6-2A  engine, engine heads, head valves disassembly v1100
...... E6-3    engine, engine heads, valve guides and valve seats v750
...... E6-3A  engine, engine heads, valve guides and valve seats v1100
...... E6-3B  engine, engine heads, head valves reassembly v1100
...... E6-5    engine, engine heads, heads reassembly v750
...... E6-5A  engine, engine heads, heads reassembly v1100 california
...... E6-6    engine, engine heads, valve clearance
...E7 engine, cylinders
...... E7-1    engine, cylinders, removal v750
...... E7-1A  engine, cylinders, removal v1100
...... E7-2    engine, cylinders, check
...... E7-3    engine, cylinders, reassembly v750
...... E7-3A  engine, cylinders, reassembly v1100
...E8 engine, pistons
...... E8-1    engine, pistons, removal v750
...... E8-1A  engine, pistons, removal v1100
...... E8-2    engine, pistons, check v750
...... E8-2A  engine, pistons, check v1100
...... E8-3    engine, pistons, reassembly v750
...... E8-3A  engine, pistons, reassembly v1100
...E9 engine, compression ring
...... E9-1    engine, compression ring, removal - check - reassembly v750
...... E9-1A  engine, compression ring, removal - check - reassembly v1100
A0 technical data
E Engine
...E10 engine, engine block
...E11 engine, connecting rods
...E12 engine, crankshaft
...E13 engine, oil sump
A0 technical data
E Engine
A0 technical data
E Engine
...... E10    engine, engine block
F gearbox
...F1 gearbox, gearbox housing
...... F1-1  gearbox, gearbox housing, removal
...... F1-2  gearbox, gearbox housing, reassembly
...F2 gearbox, clutch housing
...... F2-1  gearbox, clutch housing, removal
...... F2-2  gearbox, clutch housing, reassembly
...F3 gearbox, gears v750
...F4 gearbox, gears v1100
G transmission
...G2 transmission, pinion housing
...... G2-1  transmission, pinion housing, removal
...... G2-2  transmission, pinion housing, check
...... G2-3  transmission, pinion housing, reassembly
...G3 transmission, transmission case
...... G3-1  transmission, transmission case, removal
...... G3-2  transmission, transmission case, check
...... G3-3  transmission, transmission case, pinion - gear meshing (bevel gear set)
...... G3-4  transmission, transmission case, reassembly
D fuel system
...D3 fuel system, cylinder synchronisation 750 breva
...... D3-A  fuel system, cylinder synchronisation v1100
...... D3-B  fuel system, cylinder synchronisation california
F gearbox
G transmission
D fuel system
F gearbox
G transmission
D fuel system
F gearbox
G transmission
D fuel system
F gearbox
...... F1_1  gearbox, gearbox housing, removal
...... F1_2  gearbox, gearbox housing, reassembly
...... F2_1  gearbox, clutch housing, removal
...... F2_2  gearbox, clutch housing, reassembly
G transmission
...... G2_1  transmission, pinion housing, removal
...... G2_2  transmission, pinion housing, check
...... G2_3  transmission, pinion housing, reassembly
...... G3_1  transmission, transmission case, removal
...... G3_2  transmission, transmission case, check
...... G3_3  transmission, transmission case, pinion - gear meshing (bevel gear set)
...... G3_4  transmission, transmission case, reassembly
D fuel system
...... D3_A  fuel system, cylinder synchronisation v1100
...... D3_B  fuel system, cylinder synchronisation california
49216[/snapback]
Not using Windows? how archaic
:lol: this post is so long :whistle:
A0 Technical Data
D fuel system
E Engine
E2 head covers
E3 timing system
E4 clutch
E5 flywheel
E6 engine heads
E7 cylinders
E8 pistons
E9 compression ring
E10 engine block
E11 connecting rods
E12 crankshaft
E13 oil sump
F gearbox
G transmission
california
49342[/snapback]
Thanks for the synopsis :lol: I don't have the good quicktime. And wow that guy makes it look soo easy :whistle: btw I have cable and it only took about 5min Maybe 10min. you poor poor dialup users. I don't know if I could ever go back. :huh2::vomit:
..i love my 2.3 mb connection :)
heh does anyone have a link to where these can be purchased legally ?
I'd kinda like to have the licensed versions
