txrider Posted April 20, 2005 Posted April 20, 2005 Reading Brian's post about removing that frozen axle/bearing ( glad you didn't experience a get-off, there Brian) brought to mind some tools that would have been useful and that I use frequently. #1- The odd ball is a 3-lb rawhide mallet that has the heft to dislodge most items a 1-lb ballpeen hammer will only dent/score. #2- A 4-1/2" disk grinder. Incredible what this tool will cut through, axles, bolts, sheet stock, you name it. #3- A Dremel rotary tool with assorted accessories. Particularly useful is the 1-1/2" cutoff wheel and the sanding drum. Great for small detail metal work and deburring. #4- 6" dial caliper for checking hardware replacement diameters, o-ring replacements, etc. #5- Optivisor with at least 4-power lens. For old guys like me with failing vision who need to look at fine detail. These are only a few of the many tools required around a shop/garage used in maintaining the bikes but they are incredibly useful and might not be considered in getting started in this wonderful pastime.
dlaing Posted April 20, 2005 Posted April 20, 2005 #3- A Dremel rotary tool with assorted accessories. Particularly useful is the 1-1/2" cutoff wheel and the sanding drum. Great for small detail metal work and deburring. 49208[/snapback] I finally bought one, and one of the first things I did was cut off the worn out tips of my Allen (hex) keys.
